Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Zoom H6 Handy Recorder Troubleshooting
Recorder will not turn on
The device will not power up or respond to the power switch.
Faulty batteries
Recorder won’t turn on because of low battery life or dysfunctional batteries. Replace with four AA batteries. If the batteries are replaced and the device still does not turn on, then there might be a problem with the battery terminal.
Dirty or obstructed battery terminal
If new batteries have been placed in the terminal and the recorder still does not turn on, make sure the battery terminal is clear of debris. Dirt and dried battery acid can block the batteries from powering the device. To clean the terminals, use a disposable brush like a toothbrush to sweep away loose debris. For compact battery acid debris, use a cotton swab lightly soaked in white vinegar and wipe the terminal contacts clean. The white vinegar neutralizes the battery acid.
Faulty battery terminal
If the batteries were replaced and the device still does not turn on, then there could be a problem with the battery terminal and it needs to be replaced.
Device will not read the memory card
When the memory card is inserted into the device, the device does not detect or read the card.
Incompatible memory card
The device will not be able to read from an incompatible card. Ensure that memory card is the appropriate size and has open space (compatible cards: SD, SDHC, SDXC up to 128 GB).
Memory card is not inserted properly
An improperly inserted memory card can lead to the device being unable to read data. Remove and reinsert the memory card. If problem still occurs, then there may be debris in the slot that is preventing the H6 from reading the card.
Memory card slot obstructed
Any debris in the slot could cause the device to not read the memory card. Turn off device. Check for any debris that may be in the slot. Remove debris using pressurized air.
Screen is dim or unreadable
When turned on, the display is not visible in different lightings.
Brightness is set too low
Low brightness causes the screen to be dim. Press the menu button, go to “System” and then go to “Backlight.” Under “Backlight,” go to “Brightness” and select the brightness setting that you prefer.
Power saving mode is on
Power saving mode attempts to save battery life by dimming the screen. Press the menu button, go to “System” and then go to “Backlight.” Under “Backlight,” go to “Power Saving Mode” and select “off.”
Distorted playback
When playing back the audio, the sound is distorted.
Gain levels on the device need readjustment
Maladjusted gain levels can lead to unclear and distorted audio. Adjust knobs until audio playback is clear. Focus on knobs that are connected to the microphones. If audio is still distorted, then the issue is possibly caused by improper connections or a broken/dirty microphone.
Device settings need readjustment
If settings are not adjusted to get the desired audio, then the audio will sound distorted when played back. If the playback speed needs adjusting, press the menu button, go to “Project Menu,” select “Playback Speed,” and adjust the speed. If playback mode needs to be changed, press the menu button, go to “Play,” select “Play Mode,” and select the desired mode. If the pitch needs to be changed without changing the playback speed, press the menu button, go to “Project Menu,” select “Project Mixer,” select the track in which the pitch needs to be changed and then adjust the pitch. Lastly, if the balance of the tracks needs to be balanced, press the menu button, go to “Project Menu,” select “Project Mixer,” and change parameters as desired.
Input devices are not plugged in properly
Incorrectly inserting microphones or attachments may distort audio. Make sure that each input device goes into its designated spot oriented correctly and clicks into place.
Microphone connections are bad and/or microphones are dirty
Improper connections can cause distorted sounds. Make sure the microphone prongs are not bent or broken. Ensure the microphone slot is clear of any debris, that the microphone is oriented properly and clicks into place. Refer to this guide if mic connector is broken.
Device not recognized by computer
When connected to computer via USB, ‘device is not recognized’ appears on desktop.
USB cable is not inserted properly
Improper connection to the computer causes device to be unidentified. Ensure the USB cable is inserted properly into the device and computer. Check to see if the computer operating system (OS) is compatible (Windows XP or later, Mac OS X 10.6 or later).
Faulty USB cable
Sometimes the cable itself isn’t working properly, and therefore not letting the device connect to the computer. To confirm the problem is not with the cable itself, connect the recorder to the computer using a different USB cable.
Computer software disabled device recognition
If using Windows 64 bit, click on the Windows “Start” button. Go to “Control Panel”, click on “Hardware” and then click on “Device Manager”. Expand universal serial bus controllers. Right-click USB composite device and uninstall. On the top menu of “Device Manager”, click “Action” and then click “Scan For Hardware Changes”. Once device is automatically recognized, install the driver software.
There is no sound or volume is very quiet
Audio playback is low or not audible on the computer.
Audio level is low
Audio settings may cause sound to not be audible. Right-click on speakers and select open volume mixer. Identify if Zoom H6 appears on the panel. Click and drag the audio level until noise is audible.
Device will not record
Device will not record any audio.
There is no SD card in SD slot
Device needs memory card to record data onto. Check if there is a SD card inserted with free space.
SD card does not have enough space
Replace the SD card with a new and compatible card or delete/transfer old files from current SD card to a computer or external hard drive.
“Hold is on” is enabled in the device settings
The H6 recorder has a hold function to prevent accidental recording. If "Hold is on" appears on the display, the hold function is enabled. To disable the hold, slide the power switch to the center.
Author
with
William D'Arrigo
281 Reputation
2 Guides authored
USF Tampa, Team S5-G2, Eyestone Spring 2018 Member of USF Tampa, Team S5-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S5G2
4 Members
96 Guides authored
43 Comments
i’m getting the hold is on message when the slide toggle is in the middle
jeffroemeek - Reply Share
I have the same problem, did you find the answer?
soheila javaheri - Reply Share
I´ve got the same issue. Did you found a solution?
Christian Köhn - Reply Share
never had problem recording but levels were not showing when I was attempted to record in all tracks. Battery 2/3 full, SD card has plenty of memory.
Mal - Reply Share
Hi
the screen turns on 3 blank seconds and then it goes off completely every time I want to turn it on
audioclaveran - Reply Share
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 143
All Time: 39,991
