Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Speaker is not keeping charge
The device wont stay charged for very long if at all.
Wrong power adapter
This device requires a 5V/1A USB AC adapter with a USB to Micro USB cable in order to charge it. If an incorrect adapter is used you may run the risk of damaging the device. However, mostly anything under the 5V/1A rating will be okay, only it will take longer to charge.
Faulty battery
If the power adapter for the speaker is adequate, and the speaker only stay on while it is plugged into the adapter then most likely the battery must be replaced. Check the battery holder and its leads to see if there is anything wrong with there first. click here to see how this is done.
Speaker is not turning on
It doesn't turn on when the power button is pressed.
Faulty micro USB port
When you plug in the a working power adapter if the light doesn't turn on then the there is a most likely an issue with the port. try wiggling it around, if the light comes on at some point this may mean that the port could be loose and may need to be repaired. If it is charging it might be the mother board. click here to see how the to access the mother board.
Battery is not charged
Charge the device by plugging in the charging cable to an outlet, this will charge the device and the device will soon power on.
Speaker has bad sound quality
The sound quality has changed.
Faulty speaker grill
inspect the speaker grill, if it is dusty carefully clean the grill. If the sound Grill is cracked or broken this will effect the sound quality replace it with a brand new one for a better listening experience. Click here for a guild.
Altered sound data
The song file used for streaming music is maybe altered or corrupted. This means that the song file itself is not an original file. We suggest using another music file that is original.
AUX cable not working
Damaged AUX cable, this can can cause the music to sound dull or muffled. It is imperative to use a working AUX cable. If the music sounds dull or muffled, use a new AUX cable.
Blown out speaker
If the speakers are blown out check to see if it’s the right speaker or the left one. If it’s the right one replace the right side speaker. If it’s the left one replace the left side speaker. If both speakers are blown out replace both of them. click here for a guild.
Phone not staying Connected
I can't seem to keep my device connected to anything.
Loose 3.5 mm jack
If the 3.5 mm Jack isn't completely in the adapter, check to make sure it's completely in the adapter. Check to see if 3.5 mm Jack has dust in them, if so clean out the dust completely. if this doesn't help check to see if its the cord your using. If the problem still persists use this guild to see if the problem is internal.
AUX cable not working at the end where the phone is connected to the cable. The AUX cable needs to be checked out. If the AUX cable is not working well buy a new AUX cable and connect the cable to the phone.
Resetting the phone and the speaker
There's a power button on the phone which you are using, usually you press it down for 5 seconds it will turn off then you press that button again then it will turn back on. Resetting the Zenbre Speaker can be done by holding down button near 3.5 mm Jack.
Bluetooth is not connecting
If the speakers Bluetooth is not connecting properly check the phone to see if it’s connected appropriately. If it is connected properly try keeping the phone closer to the speaker, hence the reception can be clearer. Try keeping obstructions away from the device or phone, make sure to stay in the same room so the speaker can connect to the phone device correctly.
Author
with
Chris Maciel
134 Reputation
0 Guides authored
26 Comments
wont pair with windows 10
Louis Ordentlich - Reply Share
I have to go into bluetooth manager and unpair or uninstall the speaker, then it will come up after a minute, ready to pair. Hit that and it will work. Or leave speaker on while rebooting. It wont pair if it is already installed and you turn it off and on without rebooting your computer.
jerry - Reply Share
Same thing happens to me.
Rosanne Hallowell - Reply Share
I cannot get my speaker to turn off or work, it is frozen. I have been unable to find help concerning this product.
Kristen Burns - Reply Share
I am having the same problem.
joerhs - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 37
All Time: 14,251
