Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device won't turn on
The printer won't turn on and there are no indicator light on
On/Off switch on back
Before going any farther, make sure the power switch on the back of the device is switched to the on position.
Power cable plugged in
Next, make sure the power cable is securely connected to the back of the device and then into the power outlet.
Bad power cable
If everything is plugged in and switched on, then the power cable may be bad and should be replaced.
Printing on label is light
Pieces of the label may have light printing while others are normal, or the whole label may be faded
Darkness setting needs adjusting
The darkness, or heat setting, might need adjusting in the driver on your computer.
  1. On the General tab of the driver window, click on printing preferences
  2. Expand Device Options and then expand Head Settings…
  3. Select Darkness Wizard and click the Settings button
  4. Follow the instructions in resulting window
(Steps from Zebra documentation)
The print head needs to be cleaned
The printer may be dirty and need cleaning. Zebra recommends buying their cleaning pens for such a job and they can be readily found online.
Won't print and the indicator light is red
The top lid is open
If the top lid is open the indicator light turns red. Try giving it a good push down and wait for a click.
Out of paper
If the printer is out of paper then the light will let you know by turning red.
Printer needs calibrating
If you have paper in the printer and the lid is shut, but the light is still red then the printer may not realize there is paper inside. You can calibrate it to the labels inside the printer by going into the driver settings.
  2. Click the Tools tab
  3. Expand the Tools option and click the Tools… option above Status Polling
  4. Click the Tools button
  5. Click the Calibrate button
Paper won't feed
Printer is out of paper
First double check the printer still has paper. If it does, make sure it is securely sitting in the holder.
The top lid is open
Make sure the top is securely latched shut. It takes a good push for it to lock.
Feed button is defective
If you are trying to feed with the feed button, it may be that the button is defective and needs to be replaced. See this guide on completing this repair.
Paper feeder needs replacing
It is possible that something is stopping the paper feeding roller to not move properly. One of the feeding rollers or a motor may need to be replaced.
Author
with
Keeland Roche
158 Reputation
1 Guide authored
USF Tampa, Team 1-28, Donnelly Fall 2014 Member of USF Tampa, Team 1-28, Donnelly Fall 2014
USFT-DONNELLY-F14S1G28
1 Member
12 Guides authored
4 Comments
keep showing Printer is out of paper when there is still lots of paper
spectralabsci88 - Reply Share
while printing more than 10 labels the print job will stop after about 5 label. all the lights go out, even the back power supply light. I unplug the main A/c power input cord and the printer resets. I am only printing 1 or 2 labels at a time to prevent any power failures. Could this possibly be the power supply going bad?
thomasky78 - Reply Share
why is my Z450 printing 2 sideways labels on one 4x6? please help.
Teresa L Heitman - Reply Share
I have calibrated the printer, plenty of labels loaded and the top lid is closed.............
when I turn power on, I hear two low clicks and the light remains red and/or blinking red and green
Celeste Hertz - Reply Share
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 108
All Time: 27,703
