Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
ZTE Majesty will not turn on
No matter what you do, you can't get your ZTE Majesty to turn on.
Dead battery
If your ZTE Majesty will not turn on, you may have a loose connection. Open the back and check the battery. If the phone still doesn't turn on, you might simply have a drained battery. Replacing the battery will solve the problem.
Black display
If it appears nothing is happening and the display is pitch black, it is possible that the display is defective and must be replaced. It is also possible that the phone has the Black Screen of Death. A few solutions to that can be found in Screen of Death.
ZTE Majesty has no headphone audio
Your ZTE Majesty turns on and works normally, but when you play audio with headphones and speakers, the audio doesn't work properly.
Faulty headphones
Check with a different set of headphones or speakers by connecting them into the audio jack to see if the phone audio jack is the problem.
Pocket lint
Lint tends to built up in small crevices while the phone is in your pocket. Using a flashlight to see, remove any pocket lint with a small needle.
Broken audio jack
If the audio jack still doesn't give off any sound when you plug something to it, the cause of an audio output problem on your ZTE Majesty is a broken audio jack. Ebay sells the required audio jack.
ZTE Majesty has cracked screen
If the screen is cracked, it will have to be replaced.
Screen replacement
A helpful link on how to replace the screen, screen replacement.
To purchase a new screen.
ZTE Majesty will not charge
No matter what you do, you can't get your ZTE Majesty charging light to turn on and charge the phone.
Pocket lint in the charge port
Before tearing the phone apart, check to make sure there is no lint built up in the charge port. Using a small flashlight look into the charging port for any lint build up and use a needle to remove the lint. Lint in the charging port will not allow the charging cable to appropriately charge the phone.
Appropriate Charging Cable
Every phone comes with its own charging cable. Be sure you are using the correct charging cable for the ZTE Majesty.
Still not charging
If you have changed out the battery and the phone still won't charge, then you may need to change out the charge port itself.
ZTE Majesty speakers are not working
There is a static sound coming from the speaker. The speaker is going in and out of sound. Replacing the speaker will fix the problem.
Speaker Replacement
How to replace speaker.
Author
with
Gustavo Hernandez
209 Reputation
1 Guide authored
9 Comments
This is ridiculous, but I can’t find instructions to simply answer the phone. I touched the big phone in the middle and the green phone on the bottom and can’t pick up.
Jessica R - Reply Share
You have to slide the icon up to answer a call, not touch the actual button.=)
Albert effer - Reply Share
You need to slide the phone icon in the middle to the green icon, not actually hit the button.
This ZTE Majesty ProPlus Z899L has been crazy acking cell .I turn it off one nite I turn it back on Straighttalk said I locked the Sim card up and sent me another one butt still all I can do is receive phone calls can't call or get in the phone as if like that phone was new.lordy lordy will someone tell me what heck
Robby Price Sr - Reply Share
I have a ZTE MAJESTY PRO PLUS Z899L.I BOUGHT IT LAST MONTH. 2 LATER DAYS I TURN IT OFF & SOME REASON IT HAS BEEN CRAZY ACKING CELL.ALL I CAN DO IS RECEIVE CALLS NOT RECEIVE THEM. CANT GET INTO THE MAIN MENU CAN'T GET PASS THE GOOGLE ACCOUNT..I HAVE REBOOTED IT BUTT IT SAYS IT HAS BEEN ALL READY BEEN PRE ADVANCE LIKE WHEN I SET IT UP WHEN I BOUGHT IT ,robby1963blue@gmail.com..Anyone please help me lordy merce e
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 25
All Time: 6,464
