Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Excessive Battery Draining
The ZTE Blade V8 Pro battery does not hold a good charge when compared the phone when it was brand new.
WiFi Connectivity
Turn Wi-Fi off when not in use. The ZTE Blade V8 Pro’s battery will drain excessively when the Wi-Fi is on and searching for points of connection.
A factory reset will also help with the longevity of the battery.
Slow Processing
Cellphone takes a long time to respond when trying to access the basic functionalities of the device.
Application Crashes
Sometimes, slow processing can be a result of too many background applications running and taking up the phone’s processing power. Disable the screen lock cleaning feature. This feature closes all background processes and applications when the phone is locked or screen is turned off.
  1. Open Settings app
  2. Choose Power Manager
  3. Select Power Management for Apps
  4. Select: App protection list
  5. Select: Set all to off
Other possible fixes may include cleaning useless files and pictures out of the memory or cache. The link listed gives you multiple steps to follow to hopefully solve the problem.
https://support.t-mobile.com/docs/DOC-27...
Rapid Memory Consumption
The cellphone will not respond when there’s too many applications running at the same time.
Change SD cards
*A Secure Digital(SD) card is a small flash memory card that are used in small portable devices
Stop using the SD card as shared storage. Remove the SD card, clear the phone’s cache, and choose Forget Storage SD. If you need to use an SD card, choose a high-quality one.
Removing SD card
  1. On the left side of the phone there is a small hole. Get a tool that fits inside of the hole to push the sim and memory card slot out.
  2. The SD card is the bigger slot, it is also labeled “SD Only”
  3. Remove the SD
If more guidance is needed go to this link:
https://www.youtube.com/watch?v=8XnMOCpm...
Phone Will Not Power On
The power button won’t respond to being pressed.
Loose Power Button
Blow the conflicting debris out of the power button with canned air, or another device that will blow hard air into the gaps on the side of the power button.
Sticky Power Button
When the power button gets stuck make sure to check if the border of the button is clean. If not, clean with a Q-Tip or something that is able to get in between the small cracks.
Camera Won’t Auto-focus
Camera will not focus, with certain lighting.
Failure to Focus
This device does not have laser or phase detection auto-focus like some higher-end smartphones. During nighttime, it is best to manual focus, however in the day, the light stabilization auto-focus works well.
Author
with
WSA
51 Reputation
0 Guides authored
UW Tacoma, Team S1-G1, Liner Summer 2019 Member of UW Tacoma, Team S1-G1, Liner Summer 2019
UWT-LINER-SU19S1G1
5 Members
0 Guides authored
1 Comment
ZTE Blade V8 Pro ..
This cell fell in water. Battery changed . Buzzing sound when charger is plugged in , but it is not charging .. battery dies..
any thing i can do at home?
Siegfred Briggs - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 30
All Time: 1,128
