Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Hind legs not moving
Robot dog’s hind legs will not respond, stuck in “down” position
Legs miscalibrated
Go into the WowWee CHiP Robot Dog app and select settings. In settings there is a calibration button that will run the robot dog into calibration mode for about 30 seconds. If legs do not work, consider replacing the WowWee CHiP Robot Dog’s hind legs.
Many users experienced miscalibration with WowWee CHiP Robot Dog and did not find solution to hind legs being permanently stuck.
The wheels fall off
The wheels of WowWee CHiP Robot Dog falling off or breaking
Loose wheels
Make sure the color of the wheel resembles the color of the peg. If the colors match and wheels do not work, the wheel may be broken; remove the wheel by turning the wheel cap and then pull the wheel off. If colors are not matched, remove it as mentioned earlier and grab wheel that matches peg. Next, turn the wheel and once the shape fits into the peg, push in. If wheels are borken, visit WowWee’s parts store to find replacment wheels.
The wheels are built in such a way that WowWee made it easy to replace them. Please see how to replace the wheels in the replacing wheels guide.
Only responds to deep voices
CHiP will not respond to any voices unless they are deep in tonal range
Recalibrating voice commands
Go into the WowWee CHiP Robot Dog app and select Settings. Once in the Settings, select the “Change Voice Command” tab. The app will then have you say easy triggers for CHiP to understand. When saying the new commands, do so in different tones, this will allow CHiP to respond to many different voice ranges.
Smart Watch doesn’t work
CHiP does not respond to Smart Watch commands/Smart Watch buttons don’t work
Hardware in watch doesn’t respond to button pushes
The best way to fix this problem is to bypass the watch altogether and download the “CHiP- Your New Best Friend” app which is available on iOS and android. The app has all the same buttons and functions of the watch and allows you to control CHiP in many different ways without having to constantly reprogram the watch.
Unable to charge after multiple uses
CHiP does not charge on the charging bed after sometime of use
Charging contacts on the bed no longer send a charge to CHiP
If CHiP stops charging on its charging bed, unplug the cord that plugs into the charging bed and plug it into the port located on the front of CHiP right next to the on switch, that is the direct charging port and should fix your problem. Make sure that CHiP’s software is all up to date, if so try recalibrating CHiP instead, sometimes there is a slight error in CHiP’s system that can easily be fixed with a simple update.
102 Comments
So, cannot source broken paw motors assemblies, short of buying a complete dog for parts… any other options?
blue - Reply Share
So, found small gears to fit the paw motors, Chip now works 100%, symptom was motors turning but no movement, twisting the wheels by hand heard a clicking sound rather than a smooth whirr. 10 tooth .5 mm gear.
blue - Reply Share
Hi Blue,
Can I have your email? I have similar issue
yu geng - Reply Share
Hi blue, would be great of you could provide some more information on fixing the paw motor. Having the same problem and look for a solution. If you have pictures or a video, this would be amazing.
lan - Reply Share
Can u tell me how you took it apart?
Cc Ch - Reply Share
