Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Blender Does Not Turn On
Nothing happens when you press Pulse or Start/Stop.
Blender not in Starting Configuration
Ensure that the blender is plugged in and the silver dial, also known as the Selector Bezel, located behind the Variable Speed Control Knob, is not in the off position.
If that yields no results, consult the Use and Care Guide or call customer care at 800-222-7820.
No Electrical Power
Ensure that the power cord is properly connected and that the outlet in use has power.
Check that the fuse and circuit are not blown and the prongs of the power cord are in working condition.
If that yields no results, refer to the Power Cord Replacement Guide
Loose wire
Take off the bottom of the blender as per the Control Board Replacement Guide and inspect the circuit board for loose wires or faulty connections.
Burning Smell
You perceive a burning smell to be coming from the blender.
Motor Overheat
Allow the motor to cool by powering off the blender for several minutes before using it again.
If the smell persists, follow the steps detailed on page 15 of the Use and Care Guide or consider replacing the motor.
Does Not Chop Well
The blender works, but does not chop the food finely enough.
Incorrect Chopping Configuration
Ensure that the selector bezel is set to the correct setting (either smoothie, manual, ice crush, or puree) and that the variable speed control knob is set to the right speed.
Dull Blades
When the blender is empty and unplugged, inspect the blades for dullness. If they appear to be dull, follow the Blade Replacement Guide.
Strange Taste or Blender is Dirty
Your food does not taste like you expected.
Dirty Blender
If you are able to narrow down the cause of the off-tasting food to the blender, try cleaning it as per the instructions on page 14 and 15 of the Use and Care Guide or consider replacing the jar and blades.
Display shows "Err"
The display on the screen reads "Err" and the blender does not operate.
Motor Overheat
As per page 15 of the Use and Care Guide, turn off, then unplug the blender and allow the motor to cool.
Cole Gillespie
476 Reputation
2 Guides authored
Cal Poly, Team S25-G16, Maness Spring 2018 Member of Cal Poly, Team S25-G16, Maness Spring 2018
CPSU-MANESS-S18S25G16
4 Members
60 Guides authored
1 Comment
I left a spoon inside the blender and the blades got dinged, the clear plastic in the lid got chipped and the black lid was broken. How can I get these fixed?
Edelweiss D'Andrea - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 24
All Time: 909
