Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Device Does Not Power On
  • Make sure the device is properly plugged into a working outlet
  • Check the settings knob to see if it is currently turned to the “OFF” setting
The Cord Is Broken
  • If wires are exposed use electrical tape to mend the plastic casing around it
The Fan Is Not Oscillating
  • Make sure the “Oscillate” switch is switched to “I” and not “O”
  • Look between the fan and stand and remove any obstructions
  • Remove any obstructions on the exterior of the fan that prevent oscillation
The Casing Is Not Staying Together
  • Check the back of the fan and make sure the screws between both casing pieces are tightly secured
The Air Is Not Strong Enough
  • Turn the knob to a higher setting
  • Remove any obstructions between the fan’s screen
  • Remove any obstruction in front of the fan
The Settings Knob Won't Turn
  • Remove any obstructions between the bottom of the knob and the top of the fan
  • Do not attempt to rotate the knob further than the description of the “OFF” and “3” setting as this movement is restricted
Cameron Mattson
125 Reputation
1 Guide authored
UW Tacoma, Team S3-G4, Liner Spring 2017 Member of UW Tacoma, Team S3-G4, Liner Spring 2017
UWT-LINER-S17S3G4
4 Members
36 Guides authored
2 Comments
This is not applicable to a fan which as no switches. Just push buttons. Search for “wexford ct-166thtf” to see what I am talking about.
BRADLEY KUSS - Reply Share
Mine is not oscillating and I already checked for any obstacles. What else can I do?
Grace Rodriguez - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 728
