Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
My Drum Set Won't Turn On
The drum set won't turn on when I press the power button.
Low Batteries
If the drum set doesn't turn on, the first thing you may want to try is replacing the batteries. Please visit the Battery Replacement Guide for detailed instructions.
Faulty Connection
If you replaced the old batteries with new batteries, and the drum set still won't turn on, you might need to check the connection from the motherboard to the batteries.
Damaged Motherboard
If the drum set still won't turn on after replacing the batteries and checking the connection to the motherboard, you will most likely have to replace the motherboard.
The Buttons On My Drum Set Don't Work
Nothing happens when I press a certain button on the front panel.
Dirty Or Damaged Contact
If nothing happens when you press the buttons on the front panel, you may need to clean or replace the contact strip for your drum set.
I Can't See Any Lights
The lights on the cymbal or drum heads don't light up when I hit them.
Low Batteries
If the light(s) for your drum set light up, but are hard to see, you may want to try replacing the batteries. Please visit the Battery Replacement Guide for detailed instructions.
Faulty LED
If you have replaced the batteries and the lights are still dim, or you can't see any light at all, you may have one or more faulty LED(s) that may need to be replaced.
A Cymbal Or Drum Head Doesn't Respond Properly
Nothing happens whenever I hit one of the drum heads or cymbal.
If a specific drum head or cymbal doesn't respond at all when you hit it, you may need to clean or replace the contact for that drum head or cymbal.
The Audio On My Drum Set Is Distorted
The drum set doesn't make the appropriate sounds when my child plays on it.
Volume Switch Is Set Too Low
If you can't hear, or it is hard to hear any sound from your drum set, try adjusting the volume switch to a higher setting.
Low Batteries
If you have adjusted the volume switch and you are still having a problem hearing the appropriate sound from your drum set, you may want to try replacing the batteries. Please visit the Battery Replacement Guide for detailed instructions.
Faulty Speaker
If you are still having sound problems after adjusting your volume and replacing your batteries, you may have a faulty speaker that needs replacing. Please visit the Speaker Replacement Guide for detailed instructions.
Toggled Music/Mute Button
If the volume is fine but the background music has turned off in the middle of a jam session, you may have pressed the music/mute button. This button will cycle through various background music selections when pressed; however, one of the selections will mute the background music. To turn the music back on you can do one of two things. You can press the music/mute button located on the very right of the front button panel, or turn the drum set off for ten seconds and then turn it back on.
Aaron Klementowski
847 Reputation
6 Guides authored
USF Tampa, Team 2-8, Cagle Spring 2016 Member of USF Tampa, Team 2-8, Cagle Spring 2016
USFT-CAGLE-S16S2G8
2 Members
72 Guides authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 28
Past 30 Days: 90
All Time: 5,355
