The Venturer CR20 will keep you up to date on the time and local radio stations in addition to waking you up in the morning.
The display is distorted/not on
You cannot see numbers or they are not complete.
The screen is cracked
If there is a visible crack in the screen, it is likely that you need to replace your screen and so you should refer to the screen installation guide.
The numbers are not displaying
If you are seeing no numbers on the display, first check to see that the power cord is plugged in. If it is plugged in and you still see no numbers, you may have a power cord connection problem and should refer to the power cord installation guide.
The alarm does not sound off
"Alarm makes no noise"
The volume does not adjust
If you are unable to increase or decrease your volume, you may need to replace your volume wheel and you should refer to the volume wheel installation guide.
The speaker emits no sound
If the alarm does not sound and/or your radio does not play, you may be experiencing a problem with your speaker and should refer to the speaker installation guide.
The radio won't change stations
"Audio only plays one station"
The AM/FM tuner won't change the station
If you are unable to switch from one radio station to another, you may be experiencing a problem with the tuner wheel and should refer to the tuner wheel installation guide.
The wiring in your power cord is broken
"There is a visible tear or rip in your power cord"
The power cord no longer functions
If your alarm clock will not turn on due to a malfunctioning power cord, you may need to replace your power cord and should refer to the power cord installation guide.
Robert Myers
54 Reputation
5 Guides authored
Cal Poly, Team 5-15, Forte Winter 2013 Member of Cal Poly, Team 5-15, Forte Winter 2013
CPSU-FORTE-W13S5G15
5 Members
60 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 30
All Time: 810
