Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Monitor Will Not Charge
Your monitor is having trouble charging.
Faulty Power Input
If the monitor does not charge when plugged in, try to test the charger with another monitor to ensure it is working properly. If the charger works, then the power input may be damaged. This may require the power input to be replaced.
Drained/Dead Battery
If battery life appears to be shorter than when first purchased, try restarting the device. If this procedure does not work, the battery may be drained. If device does not turn on and is not charging when plugged in, you may have a dead battery. Both instances require the battery to be swapped.
Screen Is Unresponsive
Your monitor does not read touch input on touchscreen or does not turn on.
Frozen Touchscreen
If you are trying to move to different pages on the device and the screen is not responding to touch commands, get a pencil and push in the reset button on the side of the device and hold it for several seconds. This will turn it off and require you to turn it back on.
Screen Is Not Calibrated
If you touch the screen in a certain area but the touch command is executed in a different area, your screen may not be calibrated correctly. Look for calibration options in the settings of your device. If this does not solve the problem, you may need to replace the screen.
Blank Screen Display
If you know the battery is charged and working properly but there is nothing visible on the screen after holding the power button for several seconds, the screen may have to be replaced.
Audio Distorted/ No Sound Produced
Your monitor turns on and appears to function well, but when you try to play sound, the audio doesn't play or produces sound poorly .
Dysfunctional Speaker
First, check to make sure that the mute option is off on the device. If the sound is set to the maximum level, but there is no sound coming from the monitor, the speaker may need to be replaced.
Poor Volume
First, check to make sure that the mute option is off on the device. When the volume is set and the monitor does not produce the correct level of sound, there may be some kind of damage to the speaker. If there is any kind of damage to the speaker, the sound may be muffled or distorted. If this is the case, you will have to replace the speaker.
Device Does Not Turn On
Your monitor does not respond to the power button.
Power Button Dysfunctional
First, ensure that the battery is functional by referring to the guides found above in the Faulty Battery section. If so, you need to replace the power button.
Pauline Lara
301 Reputation
2 Guides authored
USF Tampa, Team 1-1, Nance Fall 2016 Member of USF Tampa, Team 1-1, Nance Fall 2016
USFT-NANCE-F16S1G1
3 Members
48 Guides authored
19 Comments
continuously starts and shuts off. resetted it twice
Alaska Bob Esper - Reply Share
continuously starts and shuts off. reset it twice. just got it 4 months ago from 95 dollar repair for battery replacement, do not want send it again
Same issue display screen powers on & off at random times.Battery icon shows full charge.? Uniden CS phone call = Better to spend $ on a different brand
FLASH Gordon - Reply Share
Ours always freezes and nothing but hours of pressing reset and powering it on and off, over and over, just to get the system back up and running. Any quicker options after a screen freeze it get it working quicker?
ging h - Reply Share
Mine is charging but will not TURN ON!!!
Michelle hearne - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 48
All Time: 14,879
