Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No Sound
Can't hear anything
Power is off
Confirm that the Headset is on. The Charge/Pairing Status LED should be illuminated blue. NOTE: The Headset must be powered on for use, even when you’re connected via the Mobile Cable.
Dead/low battery
Confirm that the Headset battery is charged.
Loose connection
In game console use, confirm that Wireless Transmitter is properly seated in the USB port and that the Digital Optical Cable is firmly connected at both ends.
In mobile use, confirm that the Mobile Cable plugs are firmly seated in the Headset and the mobile device.
Lost pairing
Confirm that the Connection Status LED on the Wireless Transmitter stays on. If the LED is slowly pulsing on and off, it indicates that the Wireless Transmitter isn’t communicating with the Headset.
Audio Drops, Popping or Clicking Sounds
Poor Wi-Fi transmission
For best performance, stand within 20 feet from the Wireless Transmitter.
Confirm that there is no wall or other large object between the Headset and Wireless Transmitter.
Confirm that the location of the Wireless Transmitter is clear of obstructions and isolated from Wi-Fi base stations or other potential sources of interference.
Voice Chat Drops
Most in-game voice chat drops are caused by network congestion or “lag.” They usually subside after a few moments so please be patient. In extreme cases, you may need to leave the game and return to reset the chat function.
If you use a wireless internet connection, low signal strength from your modem/router can make the voice chat malfunction. For best results, we recommend a wired connection from your modem/router to your game console.
Incorrect console setup
Confirm that the game console is properly configured for the STEALTH 500P
Mic muted
Press the Mic Button on the Headset to toggle the microphone between on and off (muted).
Mic disconnected
Confirm that the Removable Mic Boom is firmly inserted into the Headset.
Author
with
Jack Crowell
361 Reputation
0 Guides authored
UMass Dartmouth, Team 2-3, Shastany Fall 2015 Member of UMass Dartmouth, Team 2-3, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G3
3 Members
60 Guides authored
10 Comments
My transmitter is broken and I can't open it up any suggestions?
Matthew - Reply Share
My headset is stuck at max volume. ive never had a problem with them until an hour ago.
Lophius - Reply Share
did you fix it? i got the same problem suddenly
antton - Reply Share
did you fix it? i got the same problem suddenly and i dont find a solution so i was wondering if you have found out because you had problem before me.
pivos1 - Reply Share
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 105
All Time: 13,075
