CONTENT
Device Won't Turn On
  • Faulty Battery
  • Faulty Charger
  • Defected Charger Port
Sticky Keypad
  • No Key Response
  • Key Can't Be Pressed
Blank Screen
  • Disabled Display
Audio Distortion
  • Blown Speaker
Memory Loss
  • Loose Wire
  • Faulty Motherboard
The palm device will not respond or show any sign of powering up.
Faulty Charger
Check to make sure you try charging your device. If you plug the charger up and don't notice the green light that comes on indicating that the device is charging, then you may have a faulty charger. Consider purchasing a replacement charger.
Faulty Battery
If you plug your device up to the charger and notice that the green light comes on, but the device only stays on when plugged up to the charger regardless of charging time, then the battery is faulty. Replace the battery using this guide. (Palm Zire 21 Battery Replacement)
Sticky Keypad
The Keypad on your device won't respond.
No Keypad Respond.
If the keypad do not respond, the keypad maybe defected and needs to be replaced. Replace the keypad using this guide. (Palm Zire 21 Keypad Replacement)
Blank Screen
The screen on your Palm Zire 21 don't display anything, even when the device is turned on.
Disabled Display
Making sure that the device is powered on tap the screen using your figure or a pen to ensure that the screen didn't time out. If the screen still doesn't display anything try turning the device off and back on to see if anything pops up on the screen. If you still have no luck, then you have a defected screen and need to replace it. Replace the screen using this guide. (Palm Zire 21 Screen Replacement)
Audio Distortion
You have trouble hearing sounds on your device.
Blown Speaker
When listening for sounds to come from your device and you only have static, or you don't hear anything at all, this maybe do to a blown speaker and needs to be replaced.
Memory Loss
Your Palm Zire 21 does not load the operating system, or any information you save to the device can never be recovered when searching for it.
Loose Wire
If you notice that your device won't boot properly, or not at all, you may have a loose wire and need to disassemble the device and check for any loose wire(s) that should be connected to the devices motherboard.
Faulty Motherboard
If you notice anytime you save any information to your device and its never there when you try to pull it up, then this is a sign of your device losing memory. Check to see if any wires are loose that should be connected the motherboard, then power your device on then back on. If that doesn't solve the problem then you have a faulty motherboard and need to replace it.
Author
with
Jeremy Craft
301 Reputation
3 Guides authored
1 Comment
i'd Memory Loss in palm zire 21 . how do i recover my data ? please help . very important data . thnks
Hossein Ghanimy - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 23
All Time: 1,211
