Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device no longer holds a charge
Solio Bolt no longer charges an auxiliary device to the level it was once able
Confirm that the Solio Bolt is fully charged
By holding the main button on the unit for longer than 3 seconds, the light will flash green a number of times; each flash represents 20% of a charge (i.e. 4 flashes would correspond to an %80 charge).
Drained/bad battery
If the Solio Bolt has displayed a full charge, then the issue is most likely with the battery. New batteries can be purchased HERE. An iFixit guide detailing step by step instructions of battery replacement can be found HERE.
Device no longer turns on
Operating the Solio Bolt via its control button has apparently no effect
Confirm that the Solio Bolt is charged
See above.
Corroded terminals
Depending on the environments in which the Solio Bolt has been used, it is possible that the terminals of the usb cable have become corroded over time. Try using a plastic brush and some rubbing alcohol to gently scrub the usb terminals of the device, and connecting cables.
Bad battery
See above.
Bad cable
It is possible that a cable connecting the Solio Bolt to power has failed. A user could attempt to charge the device in solar mode, or replace the cable. Replacement cables can be found HERE.
The LED in the button has failed
Connect the Solio Bolt to an auxiliary device, after performing correct button input sequence, observe device to see if it is being charged despite the atypical functioning of the Solio Bolt.
The logic board has failed
This error is beyond scope of this guide. Contact Solio HERE.
Damaged solar panel
One or both of the Solio Bolt’s solar panels have become cracked, damaged or no longer functions
Replace solar panel
New solar panels can be purchased HERE. An iFixit guide detailing step by step instructions of solar panel replacement can be found HERE.
Crack in device case
The plastic case of the Solio Bolt has become cracked or damaged
Repair case
An iFixit guide detailing step by step instructions for repairing modest case damage can be found HERE.
Author
with
Ethel
324 Reputation
3 Guides authored
UMass Dartmouth, Team 1-3, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-3, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G3
3 Members
36 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 22
All Time: 1,063
