Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop Power Problem
"No matter what you do, you can't get your laptop to turn on."
Faulty charger connection
The reason that the laptop does not turn on is that the charger is not functioning
properly. It could be that the wires inside the charger may be broken or the jack that connects the charger to the laptop has been broken. Another cause is that maybe the connection between the charger port and the motherboard has been broken. In order to determine where the connection is broken, you need a digital multimeter to test where the wires have broken connection.
Faulty Battery
Before taking off the backing or bottom of your laptop, plug into charger and make sure it is charged. Another cause of a faulty battery may be an indicator that your battery needs to be replaced. Make sure to note the exact battery model and replace the battery. Also, make sure that the battery is properly connected to the laptop if you have replaced your previous battery.
Bad display
The tablet portion of the laptop may have a bad screen so consider replacing the screen. Also, consider checking the status of the graphics cards to ensure that they are compatible with the display status settings. If that is the case then consider upgrading the graphics cards.
Bad logic board
Overall, the laptop's logic board may have a problem receiving or transmitting power. Consider replacing the motherboard to a newer, compatible model if it is the situation. Otherwise, determine which part in the logic board is having problems that hinders its operation. Consider replacing that specific part of the logic board.
“Keys falling off keyboard, screen cracked, or buttons don’t work.”
Keyboard
To replace keyboard, use tools and insert under seams in keyboard, and pry upwards to lift keyboard out of place.
Broken Screen
To replace broken screen, remove back of tablet and pop off outside black cover. Remove LCD screen and replace with new one.
Buttons Don’t Work
To replace buttons, remove back of tablet. Take out broken sensor button and replace with new sensor and button.
Takes a long time to turn on, Freezes and Flashes.
BIOS problem
If it takes a long time to turn on make sure that the BIOS is working properly. It may be that your BIOS needs to be upgraded so that its operations would be performed correctly. If it freezes and flashes, then a start-up program may be taking up too much CPU and memory space. Launch Task Manager to see which start-up programs are not running properly and eliminate these programs.
Clogged Hard Drive
Try defragmenting the hard drive and deleting some files to free up space in your hard drive. In the worst case scenario, format your Hard Drive drive or replace it.
Try uninstalling several unused programs that might take up too much space in your hard drive.
To Many Start Up Processes
The computer may have too many programs set to open on start up, Try taking them off the start-up list.
Vishnupriya Bakthisaran
1 Reputation
0 Guides authored
Penn State, Team 2-20, Kaschak Winter 2015 Member of Penn State, Team 2-20, Kaschak Winter 2015
PSU-KASCHAK-W15S2G20
5 Members
24 Guides authored
1 Comment
It says no bootable device please restart system. I've tried going into the setup utility menu, enabled the secure boot option then when I go into the system configuration section like the videos I watched there is no menu the change the boot to csm
jwaldrop1981 - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 2,264
