Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
TiVo Premier XL4 Troubleshooting
The TiVo Premiere has straightforward troubleshooting due to the few main components of the box itself.
TiVo Premiere XL4 screen is not working
Screen cannot be seen when plugged into TV for the first time.
Bad cables
Make sure TV is displaying appropriate video source. Use the Input, Source, or TV/ Video button on your TV remote to change video sources. If trouble, refer to TV owner’s manual. Make sure cables are connected to one OUT jack and one IN jack. Try pressing FORMAT button on the TiVo front panel several times, and cycle through various video formats. If TiVo is connected to A/V receiver and are having trouble finding correct input, try connecting TiVo directly to TV. Check cables that you own and make sure none are damaged; your equipment may be defective. Use cables that are known to work properly.
Power cord
Check if the power source is connected in the correct ports. If the TiVo does not turn on, it is probably an issue with your TV’s power source or the TiVo’s power source. If plugs are in correctly, the problem may arise from the power supply. Replacements need to be made.
Shows are not recording
Every time I go to see a show I recorded, it does not pop up.
Bad hard drive
Try and turn on your TiVo; If you don’t hear a spinning sound from the box, the hard drive has most likely died or is in failure. Contact the TiVo company and ask to receive a new hard drive.
Circuit components are out of place
Check hard drive and make sure all circuit components are aligned properly or see if any are missing. If spotted any burnt or worn-down wires, contact TiVo company to receive a new one.
TiVo is overheating
TiVo often gets very hot to the touch and begins to malfunction after an extended amount of time while in use.
Broken fan
If the unit feels excessively hot, the fan needs to be checked if it is still working. If the TiVo is overheated and the fan is continuously working, the TiVo box may need to be placed in a different area permanently. However, if the fan is not working while the box is overheated, the fan needs to be replaced due to being broken. A broken fan will cause the TiVo component to overheat due to the cooling component not working.
TiVo has visual problems
TiVo consists of video freeze, blank screen, or problematic audio.
Bad input
If the TiVo is working and menu is seen visually, the problem may be with the input. test the input with another device, if this fails, then the input is not working. Connect working cables that show the receiving output.
Audio not functioning
No sound is coming out of my television when I am wanting to watch my TiVo.
Bad input
Check the testing mechanism of the input; connect directly to the TV. If the TiVo is working and the menu is available to see, then the problem is possibly the input. If nothing works, the input is not functional.
Bad cables
View the cables and see if any are damaged or aren’t receiving; check and see the cables are connected and fully functional. If not functional, use cables that are known to work.
Replacement Guides
TiVo Premiere XL4 Fan Replacement
TiVo Premiere XL4 Motherboard Replacement
TiVo Premiere XL4 Power Supply Replacement
TiVo Premiere XL4 Hard Drive Replacement
TiVo Premiere XL4 Cover Replacement
Author
with
Christian Schmidt
101 Reputation
0 Guides authored
Baylor, Team S1-G1, Williams Fall 2018 Member of Baylor, Team S1-G1, Williams Fall 2018
BU-WILLIAMS-F18S1G1
3 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 831
