Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No power
My TDK Life on Record Trek 360 won't turn on
Device is not fully charged
Charge it for 8 hours or more to make sure the battery is full.
Device wont turn on even after charging
You may simply have a broken battery. Check out this guide to learn how to replacement.
TDK Life on Record Trek 360 has no sound
"My songs are playing but there is no sound coming from the speaker"
Low Volume
Try turning up the volume.
Is the device on?
Check if the device is on.
Is the bluetooth connected?
Check to be sure that your device is properly connected to the speaker .
Low Battery
Be sure that your device is not low on battery. Low battery can effect the amount of sound coming from the speaker.
Distorted sound
"My music sounds weird from my device"
Is the device on?
Turn on your device and make sure it is playing.
Volume
Try adjusting the volume of the device
Is it fully plugged in?
If you plugged in your device, make sure the 3.5mm audio cable is fully inserted.
Try a wired connection
If using bluetooth, try using the 3.5 mm stereo cable instead or try troubleshooting for Bluetooth.
Sound Only from A Few Speakers
Remove objects from speaker covers
Be sure there is nothing covering the speakers as this could make it seam as though one or more of your speakers do not work.
No sound from speakers?
If your TDK Life on Record Trek 360 has sound only from only a few speakers, then those speakers may be broken and have to be replaced.
Intermittent blue tooth signal
"My bluetooth keeps disconnecting from the device"
To test or Improve the signal
Place both devices within 30 feet, or closer, and move both devices away from other Bluetooth devices, microwaves, wireless routers and other electronics.
Is the battery low?
Ensure your TDK 360 and Bluetooth device are charged and turned on.
Bluetooth device keeps disconnecting
You can try pairing your Bluetooth device again or try connecting a new bluetooth device.
Man Truong
1 Reputation
0 Guides authored
CSU Fullerton, Team 1-2, Bruce Fall 2015 Member of CSU Fullerton, Team 1-2, Bruce Fall 2015
CSUF-BRUCE-F15S1G2
3 Members
60 Guides authored
4 Comments
Turns off on its own
SGWSR - Reply Share
A360 turns off on its own
SGWSR - Reply Share
My a360 turns off on its own.
Sebbe330 - Reply Share
Same issue. Fully charged. Just turns off after a few minutes. Can turn back on manually, but it just turns off. TDK is no longer supporting the speaker. Too bad as it is a great sounding speaker for its size
Larry Reinker - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 3,831
