In Progress
This wiki is unfinished.
Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Note
Do not use rubbing alcohol to clean your steering wheel. Isopropyl alcohol has the potential to release plasticizers which make plastic and vinyl steering wheels more sticky, and will dry out leather.
First off, you'll want to figure out both the material of your steering wheel and the cause of the stickiness, as the solutions will vary greatly depending on the composition of the surface. The chart below should direct you to the best solution for the given material and likeliest culprit:
MaterialCauseSolution
PlasticDirt/GrimeSoapy Hot Water
PlasticHeatPlastic Conditioner
LeatherDirt/GrimeClean & Condition
LeatherWearLeather Conditioner
LeatherHeatSunscreen Conditioner
Dirt & Grime
The most common cause of a sticky steering wheel is dirt and grime buildup. As lotions, dirt, grease, and skin oil from your hands get deposited onto the steering wheel every time you drive, the accumulation of
Heat
Heat can cause plastics and vinyls (polymers) to break down in one of two processes. Photodegradation is when the polymer is exposed to UV-rays like sunlight. Thermal degradation is caused by heat. Your steering wheel is exposed to both if it stays parked outside, particularly if you live in a warm climate like San Luis Obispo, California.
Austin Blakely
23,463 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
5 Comments
Cristal del isuzu trooper sube torcido
Cayetano - Reply Share
Cristal isuzu trooper se tuerce al bajarlo.
Add 'Foam Rubber' to the steering wheel's that need "something" of the 2010 Honda Civic sedan... it's not quite sticky...but it is shedding and falling off...slowly.
Burke McQuinn - Reply Share
Lam sao chinh tay lái bi nghiêng về bên trai
kevin tran - Reply Share
Moteur Ford fusion 1.4 TDCI mode dégradé 3000 tours mn
4
Boukhoms Jamel - Reply Share
Past 24 Hours: 12
Past 7 Days: 40
Past 30 Days: 167
All Time: 4,633
