Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone Is Not Turning On
Power button jammed
Too much pressure might have been put on the power button while being used, allowing it to get stuck on te inside of the phonw. Replace the power button using this guide.
Dead Battery
Your phone simply needs to be charged
If your battery is almost dead, you’ll often see a low battery indicator on the screen when you try to turn it on. But, if you let the battery completely die, your phone won’t respond at all when you press the Power button. In that case, Plug it in and let it charge for fifteen minutes or so. Come back later and try to power it on with the Power button.
Phone is Frozen
Android phones can sometimes hard-freeze and refuse to respond. If an Android (as this phone is an Android) is completely frozen, your device may be powered on and running but the screen won’t turn on because the operating system is frozen and not responding to button presses.
In order to solve this problem, you may need to perform a “hard reset,” or “power cycle,” to fix these types of freezes. This cuts the power to your phone entirely, forcing it to shut down and boot back up. For instructions on how to perform a hard reset, Check This Site
Touch Screen Is Not Responding
Screen Is Dirty
If your phone touchscreen is dirty with oily finger touches, dust, or any other sticky material, it is not going to respond well to your finger impressions. Cleaning the screen with alcohol wipes may help.
Front glass screen cracked
If your phone has been cracked due to a hard fall or any other reasons, it could disable the touch ability to function because of a possible damage of the lens and sensor layer. You can replace your screen using this guide
Phone Needs A Restart
Some devices needs a good restart to get back to functioning like they are supposed to. You can restart the phone by holding the power button once to turn it off and a second time allowing you turn it back on.
Phone consistently shutting off
The phone is unable to hold power
Poor Battery Life
You may be dealing with a dead battery that needs to be consistently charged. Sometimes Android batteries needs a few minutes to cool down before operation. Since the Xperia ZL has a removable battery, you can go ahead and remove the battery of your phone and wait about 10 seconds before plugging it back in to boot it up. You can remove your battery using this guide.
Stamina Mode
If battery has poor life, the reason may result in Stamina mode being on. All those apps that you have on your smartphone may still be running in the background, draining your battery. To turn it off go to ''Setting > Power management > Stamina Mode> Turn off
Phone randomly shuts off
Phone has full battery yet randomly shut off and wont turn back on
Sudden Death
An issue that was common with Xperia Z series was the sudden death where the phone will randomly shut off and not turn on. Restart phone by holding the power and both volume up and down button. Once restarted, go to OTA updates and Sony has sent an update that prevents sudden death to occur.
Not connecting to Wi-Fi
Not being able to access the internet due to the wifi not being present
Wifi is Not Enable
Make sure that the wireless connection setting is enabled.
Restart Router or Phone
Turn off and on your phone or wireless router.
Latest Firmware
Go to OTA updates and make sure that all of the latest updates are acquired.
DHCP on router
Make sure that DHCP (Dynamic Host Configuration Protocol) is turned on, on your router.
MAC Address
Turn off MAC(media access control) filter on router and manually add your phones MAC address.
Not receiving Notifications
For some reason your notifications are not popping up on your phone
Stamina Mode
Your stamina mode is probably turned off, not allowing apps and certain settings on your phone to run properly. To fix this problem, follow the same procedure we used before for the poor battery life. Go to''Settings > Power Management > Stamina Mode> Turn on"
Factory reset
This procedure WILL reset all of your data and informations. Settings > Backup and Reset Make sure Back up my data is off. Then press Factory data reset.
Author
with
Liam Kanaley
433 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Bhusal Fall 2015 Member of UMass Dartmouth, Team 1-7, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G7
3 Members
36 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 2,728
