Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Apple CarPlay Disconnecting
The device would randomly disconnect from newer iPhones leading to Apple CarPlay malfunctioning.
Siri Inactive
One of the main reasons for this problem is having Siri inactive. The stereo would not recognize the iPhone without Siri being active. To resolve this issue, the user should turn on Siri and make it active while the device is on.
Apple CarPlay General Settings
Most iPhones would have applied Apple CarPlay restrictions applied when the phone is new. This may prevent the device from recognizing the phone; thus, the user needs to adjust that through the phone's general settings. To do so, General -> Restrictions On My Phone -> Turn Off. This process should definitely resolve the issue.
Randomly Shuts Off
The device will be running smoothly and would suddenly shuts off when the device is on.
Overheating
Having the device in direct contact with sunlight will cause the device to overheat. You should make sure to install the device where there is any type of shade to prevent any expose to sunlight. In addition, try not to keep the device running for more than 5 hours, especially during long road trips.
USB Device Not Supported With New Apple Products
Whenever you try connecting your phone via USB lightning cable to the device, the system would not identified your device or Apple CarPlay would not be working properly.
The Use of Third-Party USB Lightning Cable
Make sure to use the original ordinary USB lightning cable made by Apple, because the last few years, Apple has been releasing updates of its IOS and changing the behavior of music playback over the wired connection. Therefore, using an original USB lightning cable would ultimately resolve this issue.
Black Screen When Using Android Auto
The screen would turn black whenever the user connects their phone through Android Auto.
USB Cables
A number of users noticed that the issue disappears whenever the user disconnects their Android phone from the USB that they are using. Try switching out your USB cable while using Android Auto. In addition, Sony has just released device updates, so make sure your device has the latest update.
Beeping Sound When Device is Off
The device would beep too long when the user switches it off.
Device General Settings
Although a lot of users may see this as an issue, Sony sees it as a feature. The device's default settings force it to produce a beeping sound whenever the user switches the device off. Sometimes this feature would not work properly, which can cause the device to beep for long period of time. To adjust this, simultaneously press the "SEL" or "SOUND" button and the "6" button on the head unit. Pressing these buttons would restore the beep function.
Author
with
Abdulaziz Redha
741 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Cagle Spring 2018 Member of USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Members
60 Guides authored
16 Comments
Hello all the functions work, but the screen stopped responding to touch. Try giving reset but continue with the problem. I can only use the remote control or the iphone to operate the unit. Any suggestions? Thank you
angel - Reply Share
This is the worst troubleshooting advice, ever.
Carey Coudini - Reply Share
After while the volume randomly goes up on mine. Anyone have any ideasorchid point me in the direction of someone who does. Couldn't find anything on a Google search
Jonathan Symmes - Reply Share
I’m having similar issues but it appears that it’s only when my iPhone is connected. Both the regular music that I have stored in my phone and YouTube music will begin to distort in sound and then the device will black screen. It usually restarts as if I powered the unit down and turned it back on without killing the power to my vehicle. I’ve also encountered it just looping around playing and restarting. Someone help me please.
darkcloud0829 - Reply Share
My unit won’t play or display all of the files and/or folders on my USB stick while plugged in to usb2. I have the stick formatted to the right file system and the file types are supposed to be supported. Anyone else have this problem?
Eric Hill - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 52
All Time: 21,338
