Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Speaker Will Not Power On
You cannot get the speaker to turn on.
Dead Battery
Be sure the speaker is plugged into the power adapter when not in use. This will ensure a fully charged battery when you use your speaker.
Buttons Not Responding
If the power button cannot be pressed, there may be something around it holding it up. To fix this, try cleaning the button panel with a clean cloth, and remove any dirt on the buttons.
Damaged Battery
Sometimes after extended use of the speaker, wear and tear may occur on the battery. If this happens, follow this guide to replace the battery.
Speaker Will Not Charge
The speaker shows no signs of charging even when plugged in to a power outlet.
Faulty Outlet
If your Sony SRS-BTX500 indicates that it needs to be charged even when plugged in to a power outlet, try using a different outlet to charge the device. It is possible that the outlet you are trying to use might not be functioning properly.
Faulty Charger
If your Sony SRS-BTX500 indicates that it needs to be charged even when plugged in to a power outlet, your charger may be broken. It is possible that the wire or adapter is faulty. Try using a different charger to charge the speaker.
Faulty Port
If your Sony SRS-BTX500 indicates that it needs to be charged even when plugged in to a power outlet, your charging port my be damaged. It is possible that the charging port on the device is faulty and must be replaced to allow the device to charge.
No Sound Will Play Although Device Is Connected
Speaker is connected to device, but no audio is being played.
Volume Muted Or Low
If audio is not playing through the Sony SRS-BTX500, the speaker may be muted or on low volume. First check the speaker’s volume and adjust to make it louder. If there is still no audio, make sure the device is not muted. If volume adjustments are accessible on the connected device, turn the volume up on that device.
Device Not Actually Connected
Check to make sure the device is correctly paired through Bluetooth. The speaker may be paired with a different device. If using an AUX input, make sure the chord is properly connected to the device and speaker.
Sound Cuts In and Out
Audio is being played but it cuts in and out or crackles.
Device Is Too Far From Speaker
If connecting with Bluetooth, make sure your device is relatively close to the Sony SRS-BTX500. Move either the speaker or the device closer in proximity.
Device Not Properly Connected
If using an AUX input, the chord may not be fully connected to the speaker or device. Make sure the AUX chord is not damaged.
Matthew Okerman
1 Reputation
0 Guides authored
1 Comment
Mi è caduto…esiste il ricambio completo della pulsantiera di sinistra???
theshot.010 - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 19
All Time: 2,248
