Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Troubleshooting Sony PRS-500
1. E-Reader is not charged/charging
If your e-Reader has a dark or blank screen this could be because the device is not charged. Once your device is plugged in for 12 hours it will be able to turn on and function normally. If the screen remains blank or dark try these steps:
- Try different power outlets to rule out bad sockets
- Try different chargers to rule out a bad charger
- E-Reader will not turn on
2. Replacing the Battery
Batteries can burn out over time due to excessive charging or water damage. If you have the following the symptoms with your device it may be time to change the battery:
- Device will not turn on
- Device will not charge
- Device will not stay charged
3. Replace screen
Screens can burn out or fade over time if you have the following symptoms it may be time to replace your e-Reader screen:
- Screen is blank
- Screen is cracked
- Poor screen resolution
4. Fixing charger port
Your charger may have become damaged due to water damage or physical damage. If these symptoms occur you should consider replacing your charger port.
- Device does not work while charging
- Device does not charge
- Charger port is broken or damaged
5. Loose screw on Mother Board
Screws come loose on the Mother Board when the device is dropped or jolted multiple times. If you are having these particular symptoms with your device you may need to tighten the screws on your Mother Board.
- Device does not turn on
- Device will not reset
- Main screen is blank
- Screws on Logic board may need to be tightened
Author
with
Jessica Castro
157 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 27
All Time: 781
