Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Microphone Does Not Receive Audio
When you attempt to talk into the microphone, no audio is received.
Loose Headphone Jack
Make sure the audio is going through the headphones to ensure that the headphones are properly plugged in. If the audio is distorted or fuzzy while listening to calls or other media this could indicate that the headphone jack is only loose. This could cause the microphone to malfunction as well, and cause it to become unresponsive. Check to make sure that the audio jack is fully inserted. If you still receive these problems after you have checked replacement is required and you can refer to [3.5mm audio jack] for further help.
Dirty Device Port
Lint and dust can collect over time in your pockets and this lint can get trapped where the headphones connect to an input device i.e (Iphone, Cellular Phone, Ipad, etc). This makes it so the rings on the jack cannot make full contact with the device. A good way to get rid of this is to take a thin layer of toilet paper and a small toothpick, and use these to brush it lightly against the walls of the headphone jack to clean it. Or you can use compressed air to help remove the debris. It is important to not use anything with moisture though because this could potentially void warranties on your phone.
Microphone Button Unresponsive
The button on the microphone, when pressed does nothing.
Faulty Microphone
The microphone part itself is either broken, or it is malfunctioning. This can be caused by the part getting wet, handled too roughly, or its wiring can be wrong. To further resolve this issue replacement is required.
Sticky Button
Sometimes the microphone can be exposed to different types of materials i.e. (soda pop, juice, candy, etc.) and the residue can cause the button to be stuck. You can tell when the button is stuck like this because it will not press all the way. When the button does become stuck like this take a toothpick and clean the residue out of that area, this will help alleviate the will to stick to the sides as the button is pressed.
Audio Distortion
The quality of the sound produced by the headphones is poor or muted.
Connected Device
Ensure that the audio source is on and working. Test the sound quality when listening using a different connected device. If the audio is only distorted when listening on the original device, this means that the device is the source of the issue. You should also review the sound quality settings on your device, ensure that the settings you have are suitable for the 5-20Hz frequency that the headphones are equipped to handle.
Wiring Failure
Through use of the device wiring can get compromised, this can be caused by factors with normal use. If the wiring is compromised sound will either reach its destination at poor quality or not at all.
Damaged Speaker
Stress put on the speakers through use can cause damage. This will result in distorted audio and affect the listening experience. Resolving this issue will require speaker replacement.
Headphones Will Not Rotate
The rotation of the headphone speakers is not functioning correctly
Wear-Down with Use
Through heavy use of your headphones the swivel pieces that allow the device to be collapsible may become worn out or damaged. This problem can be resolved through a replacement of the pieces.
Swivel Malfunction
The swivel on the headphones that rotates them is either damaged or is not able to be repaired, replacement may be required. In this instance please refer to (swivel replacement guide)
Uncomfortable Headphone Cushions
When you wear the headphones the cushions do not provide any comfort.
Cushion Started Peeling
When the cushion feels uncomfortable, or if the adhesive that keeps the cushion pad on the headphones is starting to give way. Check to see if simple adhesive (glue, super glue) can re-attach the cushion pad. If not then replacement may be needed, for this please refer to [ear cushion replacement guide]. If the ear cushion stays in the place that’s great, if not you have to order another size for your headphone.
Geoff Wacker
93,084 Reputation
88 Guides authored
8 Comments
Is there a way to open up the speaker piece? There is a piece of something that rattles on the inside of the speaker housing.
Blind Burrows - Reply Share
My headphones, when turned on or I paused, will sometimes begin on full volume, hurting my ears. Why is this happening? I have an iPhone 6 on iOS 12.2
Elijah - Reply Share
MS teams cant find the mic. I can head them but they cant hear me
William B Bennett - Reply Share
What a waste of &&^&^$^ time this page is. “Sony MDR… troubleshooting” offers the helpful advice that “the wiring can get compromised”. Yep - that’s why I’m looking for help. 90 seconds of my life I won’t get back.
Hugh Jarce - Reply Share
Plugged in new from the box…..
no sound?
joanne7jlb - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 17,655
