Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The phone will not turn on
You have pressed the power button but the phone does not turn on.
Plug phone in to insure you have charge
The battery may just not have enough charge. Make sure to plug in the phone with a known working cable to insure that the battery has enough charge.
Battery may be dead
If you are using a known good charge cable, it’s possible that the battery is dead. You may need to replace the battery.
Faulty power button
The power button may be broken, and need replacement.
Screen not turning on
The screen may be dead. If you’ve tried all of the above, you may need to replace the screen.
Faulty Motherboard
Motherboard is faulty. It will need replacement.
The screen is cracked
There is one or more cracks in the glass of the screen.
Screen Replacement
Your phone’s screen will need to be replaced.
The phone turns off unexpectedly
The phone powers off suddenly and unexpectedly during use.
Plug phone in to ensure you have charge
The battery may just not have enough charge. Make sure to plug in the phone with a known working cable to ensure that the battery has enough charge.
Battery may be dead
If you are using a known functioning charge cable, it’s possible that the battery is dead. You may need to replace the battery.
Faulty power button
The power button may be stuck, and need replacement.
Faulty screen cable
The screen cable may be dislodged or is faulty. If it is firmly seated in the slot, then the cable may need replacement.
Faulty Motherboard
When the user calls, the other side can’t hear the user’s voice clearly
When making or receiving a phone call, your voice is too quiet for the other party to hear.
Microphone may be obstructed
Insure that your microphone does not have obstructions. Clean the microphone hole off with a dry toothbrush or similar.
Microphone faulty
If there are no obstructions, the microphone is likely faulty. Replace the microphone.
The user is unable to hear the other side clearly in a call
When making or receiving a phone call, you cannot hear the other party very well.
Speaker may be obstructed
Insure that your speaker does not have obstructions. Clean the speaker holes off with a dry toothbrush or similar.
Speaker faulty
If there are no obstructions, the speaker is likely faulty. Replace the speaker.
Alex Tobin
430 Reputation
3 Guides authored
USF Tampa, Team 14-5, Leahy Fall 2014 Member of USF Tampa, Team 14-5, Leahy Fall 2014
USFT-LEAHY-F14S14G5
3 Members
60 Guides authored
1 Comment
the bluetooth always turning on only
andy estrellado - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 33
All Time: 1,398
