Sony Cyber-shot DSC W150 Troubleshooting
The Sony Cyber-shot is a pocket sized 8.1 megapixel point and shoot camera , with a Carl Zeiss lens and many features such as smile shutter technology, Super SteadyShot, Intelligent Scene Recognition, and a 2.7" LCD display.
Cyber-shot does not turn on
Battery issues
Open the battery compartment to make sure that the battery is installed and facing the correct way. The three metallic squares should be facing the camera and not the latch. Make sure that the latch closes easily with little effort.
Try turning on the camera. If it does not work, continue with this guide.
Make sure that battery is sufficiently charged. Charge the battery with the included charger overnight or for an equivalent amount of time. Insert the battery.
Clean the metallic squares at the bottom of the battery with a dry cloth. This will dislodge any materials stuck in the battery and improve battery life. Insert the battery.
Buy a new battery, charge it and insert it, if it doesn't work, it is a problem with your camera. Try following the directions of your warranty if your still covered by it.
Lens won't fully extend
Screen shows Turn off and on again.
Turn off the camera, remove the batteries from the camera and wait a few minutes. Replace the batteries and turn the camera on.
If the lens will still not extend, replace the batteries and turn the camera on.
If the lens will still not extend, check to see if there is any particles in the lens barrel. Blow air in the lens barrel to remove any sand or grit that may be preventing the lens from extending completely.
The screen does not turn on
Each time you press the Display/LCD on/off button, the display changes. Press the Display on/off button until the display cycles through to a powered screen.
LCD display may be broken.
Image appears with white spots
Clean inside of lens with microfiber cloth, blower or lens cleaning fluid.
deleted
133 Reputation
0 Guides authored
Cal Poly, Team 33-73, Johann Spring 2010 Member of Cal Poly, Team 33-73, Johann Spring 2010
CPSU-JOHANN-S10S33G73
3 Members
24 Guides authored
2 Comments
hi i m doing everything wht u say but me cam does not working because the problem is the lens of the camera is not work properly and dear the screen of the cam is show turn off and on again
jagjeet - Reply Share
Jeyapaul Gurusamy - Reply Share
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 50
All Time: 13,105
