Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Sony Cyber-shot DSC-T500 Troubleshooting
Released September 15, 2008, The Sony Cyber-Shot DSC-T500 camera is part of the T series of models in the Sony Cyber-Shot family. The T series in general is a very large collection of cameras. They are all designed to be slim and include touch screens. The DSC-T500 is able to record 720p HD movies.
Will Not Power On
I press the power button, but nothing happens.
First ensure that the battery is fully charged. Then insert the battery back correctly. If the battery will not hold a charge, replace the battery, preferably with a Sony NP-BD1.
Can’t insert battery
The battery will not go in no matter how much you try.
Dirt in the compartment
There may be dirt or some other type of residue lodged inside the battery compartment. Try shining a light inside to look for anything that could block the path of the battery. Try using something thin and pointy such as a toothpick to remove anything that may be lodged inside.
Inserting it incorrectly.
It is possible that you may be attempting to insert the battery incorrectly. See our battery replacement guide to make sure you are inserting it the right way.
The camera turns off suddenly
While trying to use the camera, it shuts off unexpectedly without pressing the power button
The camera was idle for too long
If the camera was left on and you did not interact with it for a few minutes, it will shut off to prevent draining the battery while not being used. Try turning it on again. If the problem persists or it won’t turn on at all, continue reading.
The battery is drained
The battery could have simply drained and needs a recharge. Charge it for a few hours and then try turning it on again.
The battery is no longer good
The battery could be worn out and is no longer useable. If this is the case, get a hold of a new battery and use the battery replacement guide if necessary.
LCD screen isn’t working properly
Nothing is showing up on the screen, or the image is distorted
The camera is off
If there is just a black screen, the camera could just be turned off. Try powering it on and if the problem continues, keep reading.
The LCD screen is broken
The screen could be broken or defective and needs to be replaced. Follow our LCD screen replacement guide to resolve this issue.
Camera will not focus
The image is blurry when I try to take a photo
The subject may be too close
Take photos in “Macro On” mode. Make sure to position the lens farther away from the subject than the shortest shooting distance (approximately 8 cm (3 1/4 inches) (W) or 80 cm (31 1/2 inches) (T) from the lens).
If a closer photo is needed change setting to “Close focus enabled” mode and shoot about 1 to 20 cm (13/32 to 7 7/8 inches) from the W side distance.
May be set to the wrong mode
There are settings designed for motion such as Twilight, Landscape, Fireworks mode. If any of these are selected in the Scene Selection when shooting still images, the image may appear blurry.
Ensure the camera is set to “auto focus” (AF) mode. If the “Focus preset” function is selected the camera may have trouble focusing.
The camera may be trying to focus on the center screen
When shooting with the subject at the edge of the frame (or the screen), or when using [Center AF] or [Spot AF], the camera may not focus on a subject at the edge of the frame. Move the image to the center of the screen, press the shutter button half-way down which will lock AF on the subject. You should then be able to move the subject back to the edge of the frame and press the shutter button down completely to capture the image.
Anti-blur function doesn’t work
My photos are still blurry
Lighting
The anti-blur function may not work when shooting in darker lighting or night time.
Timing
Shoot the photo directly after pressing the shutter button halfway down; do not press it fully down right away.
Cannot record images
When I take a picture or video, the camera will not save it
Memory Stick
Check the free available space in the internal memory or “Memory Stick Duo”. If it doesn’t have any space available do one of the following until you can record images:
Delete unwanted photos/images
Use a different compatible memory stick/card
The camera is charging
You can’t record images while charging
The zoom does not work
Camera will not zoom in
Close focus enabled
Make sure that it is not in (close focus enabled) mode because you cannot use the Optical zoom in this mode.
Incorrect mode
Realize that you cannot use the digital zoom when you are making movies.
Depending on the image size you may not be able to use the Smart zoom
Flash does not work
The flash doesn’t go off when I take photos
Incorrect Mode
Make sure that the flash is not set to “Flash forced off”
Set the flash to “Flash forced on” in “Close focus enabled” mode or when the scene selection mode is set to landscape, beach, snow, or hi- speed.
Realize that you cannot use the flash when:
“REC Mode” is set to “Burst” or “Exposure Bracket”
“High sensitivity” mode or “Twilight” mode or “Fireworks” mode is selected in the scene selection
You are making movies
Flash bulb is broken
The bulb will need to be replaced
Chelsea Vitone
213 Reputation
2 Guides authored
UWT Liner: Group 4 Member of UWT Liner: Group 4
Community
6 Members
48 Guides authored
3 Comments
There is noise like running engine and the camera does not show the picture although it works
somqiya - Reply Share
The camera has noise like a running engine and it does not display the photo although the camera works
When camera is switched on it vibrates at a very high speed making photographs all blurred, this is regardless of camera settings
Norman Winters - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 43
All Time: 1,575
