The device does not turn on
Drained/bad battery
Replace with two new AAA batteries
Broken battery harness
See the Installing a Battery Harness Guide for the Sony Clie PEG-SL10.
The screen is frozen
The buttons and stylus will not work, and the same screen is laughing in your face! Instead of throwing your Clie, try these simple steps.
Device requires a soft reset
1.) Unscrew the top of the stylus, exposing the "reset tip"
2.) Turn the Clie over
3.) Place the "reset tip" into the reset hole and gently push until you feel a soft click
4.) Remove the "reset tip"
Device requires a hard reset
WARNING: Performing a hard reset will cause the device to lose all data!
3.) Hold the POWER button
4.) Place the "reset tip" into the reset hole while holding the POWER button and gently push until you feel a soft click
5.) Release the POWER button after three seconds and remove the "reset tip"
6.) Turn the Clie over and accept the warning message stating all data will be erased
The hard reset is not solving my problems
Calm down, there is help on the way, but it will require patience!
1.) Remove the batteries from the device
2.) Allow the device to sit for twelve hours
3.) Insert the batteries
4.) Turn the device on
The scroll wheel is not working
Broken scroll wheel
See the Installing a Scroll Wheel Guide for the Sony Clie PEG-SL10
I think I fried my motherboard
Fried motherboard
See the Installing a Motherboard Guide for the Sony Clie PEG-SL10
Steve
9 Reputation
1 Guide authored
James Madison, Team 1-4, Allen Fall 2011 Member of James Madison, Team 1-4, Allen Fall 2011
JMU-ALLEN-F11S1G4
3 Members
48 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,400
