Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera will not turn on
The camera will not respond after pressing the β€œon” button.
Faulty Battery
Make sure that the battery is fully charged before attempting to power on the device. If that does not work, then consider replacing the battery.
Device is not charging
Device does not charge when plugged into a computer through a USB port.
Try different power sources
If you are having this problem with one power source, try using a different one. For example, if you are using your laptop, try using a wall outlet. If that does not work, try using a backup battery charger.
Contact Sony
If the issue cannot be resolved, contact Sony tech support.
No sound when recording
After the 2.0 firmware update, users reported the camera was no longer recording sound.
Update firmware
Install the latest firmware update from Sony. If the problem persists, contact Sony tech support for further assistance.
Check settings
The Sony HDR-AS15 will not record sound if set at 60 or 120 frames per second in the device settings.
Memory card is not recognized
Memory card cannot be read by the device.
Check memory card
Check that the memory card is inserted in the correct orientation.
Footage is blurry
Users state that when recording underwater, the footage comes out blurry. This may be due to the curved lens.
Do not go underwater
This issue cannot be fixed because the design of the camera itself is the source of the problem. If you take underwater video footage frequently, consider looking into a different camera or case.
Case leaks underwater
While submerged, the case fills up with water.
Check O-Ring
The most likely cause of the case leaking is a faulty o-ring. If there is any visible damage to the ring, such as cracks, replace it. If there is not any apparent damage but the case is still leaking, it is possible that the ring was not manufactured properly and needs to be replaced.
Case fogs up
The case fogs up when shooting, leading to blurry images and video.
Dry inside of case
Before sealing the case, make sure all the moisture is removed. Try using a dry cloth to remove a majority of the water and let it air dry for a few minutes. If this fails to work, there is possibly a leak in the case as specified above.
Scott Scarpinato
185 Reputation
1 Guide authored
USF Tampa, Team 1-2, Sullivan Winter 2015 Member of USF Tampa, Team 1-2, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G2
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 3,423
