Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Expansion of lithium battery
Lithium battery expands making it not able to fit inside the drone’s battery port.
Charging directly after drone use
Charging the battery after using the drone will cause the battery to expand since the battery will be hot and it will overheat the battery if you immediately charge it causing the Lithium battery to produce gases that will expand the battery. To avoid this wait for battery to cool off naturally.
Using incorrect charger
When charging the lithium battery make sure to use the charger that came with the drone in the box. Using a different type of charger may cause the battery to expand due to a possible difference in voltage.
Overcharging battery
Overcharging the battery will cause the battery to expand. To avoid this, after complete drone use, make sure to only charge the battery for the specified amount of time in the directions that comes with the drone. If battery has already expanded, order another battery because it is unsafe to try and fix a battery that has already expanded.
Lost of Connection between drone and app
In order to fly the drone you need to download the app and pair it to the drone.
Not having wifi and bluetooth On
Make sure both Wi-Fi and Bluetooth is on so it can pair with your drone.If one is on and the other is off the drone somehow be unresponsive.
Range of phone and drone
You must stay in range when pairing the drone.If you are too far from the drone,the drone will not responsive to any control you attempt to make on the drone. Even after it is paired to your phone you must stay in range or else it will fly away.
Drone flies away at full power
Drone powers on at full power and flies away instantly.
Motherboard Issues
After calling the service number provided on the box, they can tell you if it is a problem with the motherboard or not and if it is they will send you a NEW syma x8c replacement drone.
Software Issues
When the drone flies away it is more complicated than just a hardware problem or a part that needs to be replaced. If the drone has flown away it is a software problem and needs to be sent back to whoever sold the product.
3 Comments
someone can help me to get the user manual??
thanks!
JOSE - Reply Share
What ypy need from it maby i can email you pics of pages
sreaumejr - Reply Share
Someone having issues with the drone not flashing to connect to the contorller when you trun it on ive trunned it off and on and got new battery chagerd it up and still the light stay solid ?? Any help would help
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,010
