Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Needle Isn't Threaded
There is no thread through the eye of the needle.
Thread the Needle
The needle needs to be threaded before you begin using your machine. Check if your thread is passed through the eye of the needle. If not, start by pulling the thread under the tension dial and passing it through the hole of the up and down lever. Then pass the thread through the second thread guide to the left of the lever. You will need to turn the hand wheel clockwise to move the needle up. Your Singer EZ-Stitch should come with a needle threader (a black plastic triangular piece), insert the wire ends of the threader through the left side opening of the protective cover and then through the needle. They should come out the other side of the protective cover. Pass the length of your thread through the needle threader wire and pull the threader out, passing the thread through the eye of the needle.
Replace the Spool
Switch out your thread for a new spool.
Stitches Won't Stay
The stitches come loose or can be pulled from the fabric.
Thread can be Pulled from Fabric
The Singer EZ-Stitch can only do what’s known as a chainstitch. That means that it uses just one spool of thread rather than the traditional bobbin and spool that most machines use. You will need to double back to complete the stitch. View our guide here.
Thread is Loose
If the stitches are loosely formed this can be because the thread tension is too loose. Alternatively, if the thread keeps jumping out of the needle, this can be because the thread tension is too tight.
Adjust the Thread Tension
Try pulling on the end of the thread, if it doesn’t pull through with relative ease, you can adjust the tension knob counterclockwise to release some of the pressure. If your stitches appear loose, you can adjust the tension knob clockwise to tighten the thread.
Author
with
Alexandra Ireland
149 Reputation
1 Guide authored
20 Comments
Cannot get the stitch right . The back of the stitch is loose.
Barbara Beach - Reply Share
The stitch is loose on the back of stitch.
The stitch is very loose on back of stitch.
I posted a comment. The stitch is very loose on the back of stitch.
The stitch is very loose on the back.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 57
All Time: 9,982
