Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Powering the device
Device will not turn on
  • Malfunctioning power button ***
Check to see if the mop is properly plugged into your wall socket, and that the socket is properly working. If you still cannot power on the device, try another wall socket. Many times button failure can be a key contributor to malfunctioning electronics
If after trying additional sockets you find that your Shark Steam Pocket Mop is not turning on, you may have a faulty power button and should refer to this link.
Device Utility
Shark Pocket will not make steam
  • Water Tank Condition ***
Check that your water tank is full, if you find it is empty, add water. Also check that the tank is free of any cracks or holes that could cause water to leak, and that the tank is properly seated in the device's housing. Often times the Shark Steam Pocket Mop will have issues creating enough pressure to generate steam if the water tank has any cracks or holes.
If you find that your tank has a crack or hole, please follow this link.
If your tank does not have a crack or hole, please consult the remainder of our troubleshooting guide and if all else fails, please contact Shark Customer Support using this phone number 877-581-7375.
Cannot select steam setting
  • Setting malfunction ***
Check if the mop is properly plugged into the outlet and turned on. If it is on and still not functioning, try resetting the mop by plugging it into a different outlet. Add water to the tank if it is empty then try selecting the 'STEAM' setting once more. Often times being unable to select certain settings is indication of a malfunctioning power socket, malfunctioning buttons.
If problem still persists refer to this link or call Shark Customer Support at 877-581-7375
Floors are left cloudy, streaky or spotty after steaming
  • Excessive residue ***
You should check the cleaning pad if it is dusty or grimy. If this is the case, you should flip the pad or replace it with as proper clean one. Check to see if the mop did not use an excess amount of water and stained the floor by not removing all the detergent. If this is the case, you should rinse the floor with pure water, let it dry and reuse the mop.
If the problem still persists refer to the link.
Mop leaves excess water on floor after cleaning
  • Drenched cleaning pad ***
The cleaning pad may have too much water in it. Unplug the mop and change the pad. If the problems still persists, refer to the link.
Maadh Al Mazruii
1 Reputation
0 Guides authored
USF Tampa, Team S13-G7, Cagle Fall 2017 Member of USF Tampa, Team S13-G7, Cagle Fall 2017
USFT-CAGLE-F17S13G7
4 Members
60 Guides authored
30 Comments
Steam head won’t lock on to base
dwaynegreer1 - Reply Share
Where is the link for the Malfunctioning power button ?
J Robey - Reply Share
This website in addition to the pdfs on the other website’s above this one have the worst troubleshooting section in a manual I have ever seen.
peter roberts - Reply Share
I have talked to Two people today after 4 or so minutes there gone and you ask me to do a survey. Can’t give an honest reply when you leave me hang , wait for options to repair my machine. Model # S3501C 13
Tank is full , bottom is warm but will not inject any steam at mop head. The pump seams to be creating some pressure but no steam is coming out.
HELP !!!!!!!!!!!!!!!!!!!!!!
Glenn Orchard - Reply Share
I’m having the same exact issue, did you ever find out the cause? Thanks!
carrienjason777 - Reply Share
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 46
All Time: 29,226
