The Sega Game Gear, a portable version of the Master System, was Sega's first hand-held game console.
Gamegear won't turn on
Battery Issues
First, make sure the batteries are intact. Second, if your batteries have been used for around 5 hours, it has depleted all its energy. Simply replace the old batteries with new ones.
Contains new batteries, but still won't turn on
Use the AC adapter provided with the game gear to power the console, make sure you are using the correct model number (2103). Using the wrong AC adapter may result in damage to your unit.
Audio Issues
Simple Fix
Plug in a headphone compatible with 3.5mm audio jack onto the console. The sound will now come out of the headphone instead of the game gear.
Hard Fix
Often if the speakers emit little to no sound but the headphones work fine, a capacitor needs replacing. See Note.
Getting Scrambled Picture
Brightness Control
Adjust the brightness control dial located on the left side of the game gear to help reduce the problem.
Interference with other electronics
Try moving away it from other electronic devices, such as: television, radio, cell phone, or any other type of electric interference.
Buttons Not Working
Clean the button contacts on the logic board. If the carbon has worn down you can spray the buttons with a miniscule amount of carbon type paint that is commonly used to fix car window defrosters.
Additional Info
Electrical knowledge will be needed to fix the faulty capacitor, here is a video that will guide you to fixing and replacing the capacitor.
Author
with
Brett Hartt
132,682 Reputation
144 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
16 Comments
I just recently got a used Game Gear and it works great except the brightness knob keeps coming off. Can you recommend a method of putting it back on permanently? Thanks.
alfredscudiero - Reply Share
I have a game gear that was unused for quite a while, there were batteries in it that exploded. I cleaned the battery terminals. and put new batteries in. Now it only powers on for a second and shuts off. What can I do?
michaelcarter6 - Reply Share
I have the same problem
TheCakeIsALie - Reply Share
I think this has to do with dried out capacitors. "Recap" and it should work again.
CORED3SIGN - Reply Share
What do you mean "recap"?
Nick Mancini - Reply Share
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 149
All Time: 40,983
