Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Memory card not reading
The memory card cannot store any pictures.
No memory card inserted
On the bottom of the camera there is a compartment that houses the Memory card and the battery. To open it, slide the lock to the left to open. Check if the memory card is inserted, if it is not, insert a memory card. Then lock the compartment by sliding the lock to the right.
Memory card locked
On the side of the memory card there is a lock slide. This may be in the lock position, preventing the memory card from being read.
Memory Card is broken
The pins on the memory card may be scratched or there is a crack in the memory card causing the memory card not to be read.
Camera won't auto focus
The camera’s picture is always blurry.
Push capture button down halfway
On top of the camera the shutter button needs to be pushed halfway to auto focus on the object in the lens.
The front lens may be dirty
Dust or smudges could be present on the lens. Take a lens cleaner rag and gently clean/ wipe off the lens.
Camera could be in Auto focus or Manual Focus
Press the Menu button. Scroll down and Check if the Focus option is set to AF for Auto focus.
Flash is faulty
The flash does not work when I take a picture..
Flash is not popped up
Make sure the Flash is turned on. To do this, press the left directional pad with the downwards arrow (Flash Symbol)
Press the Flash Symbol button on the side of the camera, located next to the Flash.
Make sure your hand is not on top of the Flash.
Wiring or motherboard problems
A wiring connection on the motherboard may have gotten loose and is not connected. If not a component in the motherboard may have been short circuited and is now broken.
Flash is not set on
Flash is not needed
There may been enough light around the in-frame object so the camera’s flash in not necessary.
Camera wont turn on
Camera does not appear to have power.
Low Batteries
On the LCD screen locate the battery symbol in the top corner. If the Battery symbol has low bars or is flashing with no bars, this indicates that the battery is low on charge. Replace batteries.
No batteries
On the bottom of the camera there is a compartment that houses the Memory card and the battery. To open it, slide the lock to the left to open. Check if the battery is inserted, if it is not, insert a battery. Then lock the compartment by sliding the lock to the right.
LCD screen is broken
The camera may be on but the LCD screen is not lighting up. To check if it’s on try using the optical zoom while the camera is in auto mode. Also check to see if you can hear the shutter close when the shutter button is pressed.
Shutting down suddenly
The camera shuts off suddenly.
Low Batteries
On the LCD screen locate the battery symbol in the top corner. If the Battery symbol has low bars or is flashing with no bars, this indicates that the battery is low on charge, replace batteries.
Defective Batteries
Open the battery housing and check to make sure the receiver pins on the battery are not damaged and are clear of any debris. If problem persists replace battery entirely.
Mother board or wiring problems
The motherboard may have short circuited or some part of the motherboard may have broke. Seek a professional for assistance.
Cannot capture pictures
Pictures are not showing on the LCD screen
Capture button broken
Try pressing the shutter button and listen for the camera shutter sound to make sure the button is broken and not something else.
Camera not turned on
Press the Power Button to turn on the camera. If it is still not turning on the batteries might be dead, or not inserted.
Lens cap on the lens
Remove the lens cap by squeezing the edges of the lens cover, then take the lens cap off gently.
Author
with
McGregor Coyne
248 Reputation
1 Guide authored
USF Tampa, Team 15-3, Remmell Spring 2016 Member of USF Tampa, Team 15-3, Remmell Spring 2016
USFT-REMMELL-S16S15G3
4 Members
36 Guides authored
1 Comment
Hello, my camera has not been turning on for over a year. I have replaced the battery and it is still not turning on. The camera is not physically damaged and was fairly new. What can I do?
Kristina Simon - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 29
All Time: 1,920
