Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Samsung Series 7XE700T1A Troubleshooting
The Samsung Series 7XE700T1A was made in August of 2011 in China.
Unresponsive home button
Your home button is too sensitive
Replace with apps
If your power button is being faulty, you can replace it with an app from the app store that overrides the issue by giving you access to your home button and other utilities from your screen. This allows you to no longer worry about pressing to hard on your home button or if your home button stop working. Some apps that can help with this are My Home Button, Easy Touch, and Button savior.
Null charging port
Your charging port isn't charging
Dirty charging port
Sometimes the port can get clogged with small debris. If this is the case take a small brush or toothpick to clear out the debris. Do not use anything metal and be gentle when clearing debris so you do not damage the inside of the port. Liquid can also get trapped in the port as well. If this happens take a small piece of a paper towel and roll it up to fit in the port and clear out the liquid.
Replace port
If you need a new port, you can replace it yourself. After buying a new port piece, take off the back of the tablet to reach the inside. Then you can unscrew the faulty charging port and screw in the newly bought port.
Impaired volume button
Is there even adjustable sound on this?
When performing troubleshooting for the volume button be careful to consider all possibilities. Are you sure the volume button is the source of the problem? Was your device recently damaged (factors of damage may include but are not limited to heat, dropping, water damage, shock, pressure, etc…). If so the volume button may not be the source of the problem. Is your device due for a potential software update? Perhaps are the speakers not functional rather than the actual volume button not working? If all the above have been considered then it is feasible to proceed to begin replacing the volume button.
Unresponsive Power Button
The power button on my device isn't working.
Check the Protective Case
For some owners, they buy a protective case that could potentially hinder the power button from coming out of its slot once pressed down. If you have one around it, try taking the case off of the device to see if the button was just constantly being pushed down.
Replace Power Button
If you want to replace the power button on your device, go online to https://www.youtube.com/watch?time_conti...; there is a video that will help you through every step to change out the power button. You will need the required tools in order to complete this task.
1 Comment
My Samsung Series 7XE700T1A turns on but displays black screen. Help me solve this issue.
Abdul Jawad Alhassan - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 616
