Phone Won't Turn On
When the power button is pressed, but the screen stays black and the phone won't turn on.
Drained/bad battery
Attempt to fully charge your phone. If the phone won't turn on while plugged into a working outlet, the battery may be defective and you will need to replace it.
Bad display
It is possible that it appears your phone is not turning on because the display is dysfunctional. In this case, the best option is usually to replace the screen.
Cannot Make or Receive Calls
Phone displays "call failed" when attempting to make a call.
Check with carrier
Check with your service provider to see that they provide service in your area. Also check that you are up to date on your bills and your service hasn't been terminated.
Inspect Sim Card
Make sure that your sim card has been properly inserted into the device. If your phone still says "insert sim" after you have inserted it, your sim card may be bad and will need to be replaced.
Phone Won't Ring
Phone makes no sound when receiving a phone call or text message.
Check volume
Make sure the volume level is not too low. The volume level keys are located on the left side of the phone.
Broken Speaker
If your speaker has been exposed to moisture or large noise amplitude, you may have blown out the speaker in your phone.
Loose speaker connection to motherboard
The connection from the speaker to the motherboard may have become loose, in which case you will need to repair this connection.
Keys Don't Work
Keys get stuck or illicit no response from the phone.
Debris in Keypad
You may have debris lodged underneath the keypad that is preventing proper function. You might try blowing on the keys; if this doesn't work you may have to remove the keypad in order to remove the debris.
Replace Keypad
The keys on your keypad may be defective, and will need replacing.
Faulty Logic Board
If neither of the above solutions worked, the problem may be a faulty logic board. In this case, it will need to be replaced.
Screen Doesn't Work
Your phone is turned on but there is no picture on the display.
Brightness too low
It is possible that you accidentally changed the brightness setting all the way to the lowest, in which case you just need to go into the settings menu and adjust the brightness back up.
Defective LCD screen
If only a light turns on when starting the cell phone, the LCD screen is most likely defective and will need replacing.
Discolored screen
If the screen is discolored, cracked, has dead pixels or is blotchy, the screen will need to be replaced.
Laura MacCarley
276 Reputation
2 Guides authored
Cal Poly, Team 11-23, Maness Winter 2011 Member of Cal Poly, Team 11-23, Maness Winter 2011
CPSU-MANESS-W11S11G23
4 Members
60 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 21
All Time: 1,261
