Phone will not turn on
When you press the power button, the phone does not turn on.
Battery has lost charge
If your phone does not turn on, the battery may have lost charge. Let the phone charge for an extended period of time. Attempt to turn on the phone while it is still plugged in.
Bad logic board
If your phone does not turn on after charging, the logic board may have failed and needs to be replaced. Follow the guide for replacing the logic board.
Battery will not hold charge
After charging the battery, the battery dies quickly.
Old or bad battery
It may be that your phone has a bad battery, if so, buy the battery. Use the guide to replace the battery.
Keyboard buttons do not work
When pressing a button, it is nonreactive.
Dirt between button and logic board
The button(s) may not function due to dirt build-up between the button and its contact on the logic board. Use the guide to take apart and clean the buttons.
Broken buttons
If you can see physical wear or damage to your button(s), the button(s) may be broken. Replace the keyboard using the repair guide.
Phone works but nothing appears on display
The phone makes and receives calls, but the display is blank.
Broken or loose connection
If the phone appears to function correctly but the display does not, the screen may be unplugged or broken inside the phone. Use the guide to take apart and check the display connection. If the connection appears to be intact, buy and replace the screen using the guide.
Broken or cracked main display
If the main display appears cracked or broken, it may need replacing. Follow the guide for replacing the main display.
External display
The external display is blank, but the rest of the phone functions.
Broken or cracked external display
The screen may be damaged internally from impact or heat. Follow the guide for replacing the external display.
Woon Julie Gonzalez
1 Reputation
0 Guides authored
Cal Poly, Team 11-5, Forte Winter 2010 Member of Cal Poly, Team 11-5, Forte Winter 2010
CPSU-FORTE-W10S11G5
5 Members
60 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 26
All Time: 1,238
