Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Non-Discoverable Bluetooth/WiFi
The Bluetooth or WiFi is not searchable or does not show any sign of being on.
Bluetooth & WiFi Interference
Ensure the speakers are close together to establish a connection, recommended distance is no more than 6.5 feet. Make sure there are no walls between speakers and other WiFi devices are not being used in close proximity of the speakers. If the Bluetooth is still not discoverable, consider replacing the Bluetooth module. If the WiFi is still not discoverable, consider replacing the WiFi module.
No audio
The speaker does not emit any sound when powered on and connected to source.
Faulty Speaker
The paired device should be turned on. The volume should not be at muted or at minimum. Make sure the speaker is compatible with the devices that are to be paired. If the device still fails to produce sound, consider replacing the speaker.
No Low Frequencies
Bass is missing in the audio, giving an effect of high pitch sound.
Damaged Subwoofer
There could be a huge difference in sound quality with no bass. Try changing the Eq setting of the input audio from the connected source. If there is still no bass, then consider replacing the subwoofer.
Unresponsive Touch Panel
The touch panel controls do not change the volume and/or the mode.
Faulty Touch Panel
There should be no static electricity interfering with the device. Check by touching the device to a grounded piece of metal. Unplug the power cord and plug it back in. If the touch panel does not work, consider replacing the touch panel.
No Power/Connectivity
The cable ports do not connect or power the device.
Defective Micro-USB Plug In Port
Ensure you have the Micro-USB plug in the Micro-USB port. Check to see if the Micro-USB cable is damaged or broken. Check if the plug in port is properly connected. If it still does not work, consider replacing the Micro-USB/Power Port Panel.
Defective Power Port
The power plug should be plugged into wall outlet. Check to see if the cable is damaged. Check if the power port is properly connected. If it still does not work, consider replacing the Micro-USB/Power Port Panel.
Muffled Audio
High frequency sounds are muffled resulting in low quality output.
Damaged Speaker Grill
A damaged speaker grill can cause the sound to be muffled. If the speaker is not damaged, then the cause of the audio being muffled and suppressed is the speaker grill. Consider replacing the speaker grill.
Non-Functioning Device
After all repairs, the speaker is still not functioning properly.
Water Damage
Water can cause the motherboard to fail. Try to wipe the motherboard with a dry cloth, and power it on. Some devices shutdown when a short is detected, so after quick dry the device will turn on. If the device still does not turn on, then consider replacing the motherboard.
Taylor Bratsch
6,174 Reputation
14 Guides authored
8 Comments
Speaker turns on by itself.
True Story - Reply Share
What should be replaced if the speaker turns itself off intermittently. Once it turned off, it may turn itself on again (from audio cue). Also the led light is not lighting up anymore.
Nicholas - Reply Share
I Love My Samsung 1R Omni directional speaker ! It has sound quality that that rivals my bose sound system ! What's suddenly?It started disconnected after a short time of operation ! Curious, if it's repairable, and if so, who have fivex, it send it in to you, do you know the answer to that problem? Let me know and send me information on your ship it to and we'll see what we can do a ballpark on the price also. !
Jeff Cotter - Reply Share
basically all you ha ve to do with samsung products is to not buy them. period.
Barna Olvedi - Reply Share
My speakers do not work on the smart TV since I changed broadband company
waynebarker838 - Reply Share
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 32
All Time: 4,502
