Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Fails To Charge
You have trouble getting the device to charge to 100% battery capacity.
Faulty Battery
If the device fails to hold a full charge, the battery may be corrupt. Replace the faulty battery with a new battery. Search for “Battery Replacement AA-PB0UC3B”.
Faulty Charger
If the device fails to charge or hold a full charge, the charger may be corrupt. Replace the faulty charger with a new charger. Search for “Samsung Q1B Ultra-Mobile PC Adapter Charger".
Overheating
Temperatures rise to unsafe levels which can damage users or components of device.
Dirty Vents
After removing the back cover, spray canned air at vents from inside to outside to remove dust and dirt. Then gently clean the fan blades with a tissue or q-tip.
Insufficient Thermal Paste
Remove the CPU to clean off the thermal paste that has been currently applied. Scrub it gently with a q-tip coated in rubbing alcohol until all of the paste is gone. Place a pea sized ball of thermal paste and return the CPU to it’s socket.
Old/Faulty Vents
Using a drill and a wide circle bit (1” or larger) drill a hole in the back cover, then glue mesh over the hole to prevent foreign objects from entering.
Screen Freezes
Your screen froze and you can not get off of the page you were on anymore.
Device Is Overworked
Using a lot of programs simultaneously could make the device run more than it could handle and make it freeze. Restart the device by pressing the power button. Wait a few minutes before turning it back on.
Screen Is Broken
If restarting the device does not work, the screen may be the problem. You would need to replace the screen by first purchasing a replacement screen. You can purchase one from this website: https://notebookrepair.co.uk/index.php?c.... Once purchased, you can follow the replacement guide here.
Device Has A Virus
Viruses could damage your software and make your device malfunction. You would need to reboot your device and install anti-virus software.
Unresponsive Buttons
The buttons or joystick do not respond to pressing.
Dirt
Test pressing the buttons or moving the joystick. If they seem to stick or grind against the casing, there may be dirt or foreign particles inside the button housing. First try a Q-tip slightly damp with rubbing alcohol, or try scrubbing with a soft electronics cleaning brush. If this fails, try a can of compressed air.
Software Issue
If the buttons do not stick but are unresponsive, it could be a problem with the software, try restarting the device.
Faulty Button/Joystick
If cleaning and restarting have not fixed the problem, the button or joystick may be faulty. However, many of the controls can be accessed on screen with the stylus. As a workaround, replace the buttons and joystick controls with a USB or bluetooth connected keyboard and mouse.
Lastly, if applicable, broken buttons can be replaced.
No Audio or Static Audio
Your device is not producing any sound or it comes out as static.
Faulty Speakers
If there is no sound exerted from the speakers and the device is turned up to maximum volume, the speakers may be defective and may need replacing. You can follow our step-by-step replacement guide here.
Broken Headphone Jack
If you have attached headphones to the device and there is no audio, the headphone jack may be broken and would need to be replaced. We have a replacement guide you can follow here.
Richard
36,254 Reputation
11 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
All Time: 512
