Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
General Phone Glitches
My apps keep freezing.
My device crashes/resets.
I can't view email attachments or website images.
My data isn't syncing.
Restart your tablet
Shut the tablet down by holding the power button and turning it back on after it is fully shut down.
If this does not fix the problem, perform a hard reset by holding the power button, the volume up button, and the home button. When prompted, press "reboot system now".
Wipe your cache partition
(BEFORE YOU START: Wiping the cache partition will remove any temporary files that may be causing an issue with the device; however, all personal files and settings are not affected by this action).
1. Ensure the device is powered off.
Note: If the device is unresponsive/frozen, press and hold the power button (located on the top-left edge) for approximately 10 seconds or until the device power cycles.
2. Press and hold the volume up button (located to the right of the Power button; ensure right side of button is pressed) and the Home button (located at the bottom in the middle).
3. While continuing to hold the Home and Volume Up buttons, press and hold the Power button until 'RECOVERY BOOTING' appears in the upper left then release all buttons.
4. Select wipe cache partition.
Note: The volume up/down buttons highlight the function and the Power button will select the action.
5. Select reboot system.
WiFi Does Not Work
I have a strong WiFi connection, but my internet doesn't actually work.
Use Samsung's Kies software on your computer to do a firmware upgrade on your tablet
Warning: the firmware download is large and can take up to an hour to complete the upgrade. You can download Samsung's Kies software here.
Change the WPA encryption on your wireless router from AES to TKIP
Basically you are changing the security of your WiFi to one that is better suited for this tablet.
This process is unique for different routers, so check the manual of your router. Search the instructions for "How to change my AES encryption to TKIP" for your specific router. It may also be beneficial to call your internet provider for more information.
Tablet Turns Off Randomly
My device continues to shut down randomly while it's being used.
Determine if issue is due to a glitch from a third party app or from a pre-installed app
If a third-party app is causing this problem, then the device should not freeze in safe mode. Otherwise, it’s an issue with one of the pre-installed app or with the tablets firmware itself.
1. Boot the Samsung Galaxy Tab in "Safe Mode".
2. If the tablet is currently on, press and hold the power key for five seconds to turn it off.
3. With the device completely turned off, press and hold the power key for two seconds to turn it on.
4. Right after the Samsung logo displays, hold the volume-down button until the tablet loads to the lock screen.
5. “Safe mode” should display in the lower-left-hand corner of the phone.
6. Reboot the phone normally in order to exit safe mode.
More information on a hard reboot for a Galaxy Tablet can be found here.
If the tablet still freezes in safe mode, you have to perform a factory reset.
This factory reset will delete all of your data and return it back to "fresh-out -of-the-box" condition.
Factory reset may be done in safe mode and by selecting "wipe date/factory reset".
Suppress app
Delete, uninstall, or disable the app causing glitches.
Back Cover Bent or Warped
The back plastic cover of my tablet is bending or becoming deformed.
Ask your Samsung provider for a new back cover
See if they might be willing to give you a new back cover. Samsung manufactured some defectives ones, and this issue is not due to overheating. They will not necessarily give you a whole new device.
Refer here to see Samsung's statement about defective back covers.
Poor Battery Life
My battery does not last more than a couple hours.
Adjust battery saving settings
A few things you can try are:
- Turn power saving mode on.
- Turn wifi and location settings off.
- Set screen on basic color scheme at 20%.
- Make sure no apps are running in the background by going into Settings -> "Applications" -> "Application Manager" -> "RUNNING" -> press an app -> hit "STOP".
Examine your charger
If you are using a quick charger or a charger that is not the original, this will decrease battery life.
Try bump charging. Bump charging gives your device an extra full charge.
In order to bump charge:
1. Charge your tablet until it gets to 100%.
2. Stop charging the device for 1 - 5 minutes.
3. Plug the tablet back in the charger and continue to charge it until it reaches 100% again.
(You can perform this task with the tablet on. Bump Charging is even more effective if the device is powered off.)
Replace the battery
This is a more complicated process, we have a link giving you the tutorial for this process here.
Tara Fussell
1,014 Reputation
2 Guides authored
Cal Poly, Team 12-15, Maness Fall 2015 Member of Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Members
60 Guides authored
9 Comments
Can i reset the ram of my tab also?please i need to know
nhelamie - Reply Share
My Computer does not recognize my tablet when I plug in the USB both on WinXP and Win7. How can I fix this? My device also does not see it.
Jen Beck - Reply Share
I just replaced my battery on my tab 8.4 , charged it, and it en’t turn on. How do I fix it?
Marion Ball - Reply Share
my tablet starts up real slow……then i get…PROCESS SYSTEM ISNT RESPONDING…….then it doesnt connect to wifi…please help
Lisa P - Reply Share
Why is this happening new bat put in and still does the same Charges 100%
flat 2 days later even though turned off. Useless tech ???
T.T - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 27
All Time: 23,294
