Tablet will not power on
No matter what is done to the device, it will not turn on.
Press and Hold Power Button
If this does not work, continue on.
Blockage in the USB Port
The simplest solution for the device failing to turn on is to make sure that there are no obstructions in the Micro USB Port, as this may cause issues with charging the battery. Visually inspect the port to make sure it is free of debris or any other foreign object. If you find an obstruction in the port, gently blow into the port or use a toothpick to free the object. With the object removed, the device should charge correctly when the charger cable is attached. If none of these solutions work, you will have to replace the motherboard. Refer to the motherboard replacement guide.
Faulty Charger
Another simple solution to check for is to make sure the battery charger is not faulty. This can be done by exchanging your normal charger with a different micro USB charger. Allow time for the device to charge and try to turn the device on. If a different charger also fails, try charger on another device to check the charge, if works on another device, charger is not the issue. This means that the battery may be the issue and may need to be replaced. Refer to the battery replacement guide.
Faulty Micro USB port
If neither of the previous solutions work, then the issue may lie with the micro USB port. If so, then it may need to be replaced. Refer to the motherboard replacement guide.
Faulty Display
If device powers on and nothing appears on the display, refer to the display replacement guide.
Bad Motherboard
If none of the previous solutions work, then the issue may be the motherboard. Refer to the motherboard replacement guide.
Tablet is stuck at Logo screen
Soft Reset
This soft reset does not tamper with any of your data. Start off by holding down the power button until the device turns off. Wait a few seconds and then proceed to hold down the power button until the device turns back on.
Software Issue
WARNING - this option will erase all personal saved data on the device, use as last resort!
With the device powered off, press and hold the volume up bottom, home button and power button at the same time until you see “recovery mode”. The device will display several options. Use the volume buttons to scroll through the list and select “Wipe date/factory reset”. Press the power button to confirm the selection. Choose “yes—delete all user data”. Confirm the option with the power button and then select “reboot system now”. Confirm the option by pressing the power button again. If this option fails, replace the motherboard. Refer to the motherboard replacement guide.
Tablet Overheats
If tablet is exceptionally hot.
Soft Reset
Bad Battery
If the device continues to overheat, the battery may be defective. Refer to the battery replacement guide.
Tablet performs slowly
Applications causing issues
Sometimes apps can run incorrectly. Power the device off and on (reset it).
Close any running applications
If resetting doesn't fix it, try downloading an app activity monitor. If you find any apps that are misbehaving (high usage when not being used), close those applications (stop it from running).
Uninstall applications
If you find that the apps that you have closed are still causing the device to run slow, uninstall them (remove from device). To do this, go to your Settings application, tap App info, Uninstall, and then OK.
Make sure that your device is up to date and running the latest software
Start by navigating to the System Updates page inside the aforementioned Settings application. Then, tap Device Software, then Check Now. If an update is available, all you have to do is follow the prompts to install it.
Faulty Motherboard
If none of these solutions work, your motherboard may not be working. Please refer to the motherboard replacement guide.
Tablet doesn't produce sound
Software issue
It's possible that an issue in the software is causing the device to not be able to produce sound. Try to fully restore the software on the tablet to make sure that this is not the case.
Faulty speaker or headphones
Check to make sure that your specific set of headphones is not the thing causing the issue. To do this, use them on a different device. If that set still isn't working, find a different pair of headphones and try them. If you believe that the speaker is the problem, check to make sure all speaker connections are functioning. If sound still isn't produced, your device's speaker may be the issue. Refer to the speaker replacement guide.
Faulty auxilliary jack
If none of the above works in regards to your headphones, you may have to replace the auxiliary jack (headphone jack). If all else fails, a motherboard replacement may be needed. Refer to the motherboard replacement guide.
Aaron Ligocki
31 Reputation
0 Guides authored
USF Tampa, Team 11-1, Cheng Spring 2016 Member of USF Tampa, Team 11-1, Cheng Spring 2016
USFT-CHENG-S16S11G1
4 Members
72 Guides authored
9 Comments
My Samsung Galaxy Tab 3 Lite uses English & then other languages that I do not understand. Nor do I understand how this happen. Can you please advice me as what to do? It seems to preform quite well with the exception of the languages other the American English
dbreest21 - Reply Share
Hi my Samsung galaxy tab 3liteSM-T110 battery is always running down to quickly and I have turned apps off and turned wife off when not using it but it stills runs down faster than it should do
Paul Bell - Reply Share
My Samsung comes up with message. "Unfortunately, Samsung keyboard has stopped.
Ann boyce - Reply Share
My tablet will not take front screen photos. How do I fix This? Other comments answers GUY WHO FAST LOOSING POWER TURN ON LOW POWER MODE AND TURN DOWN UR BRIGHTNESS
Lanie Landavere - Reply Share
guy with keyboard problems goto settings and keyboard and u probably haveclots of languages on by mistake or other keyboard guy must have turned it off
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 41
All Time: 13,848
