Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Galaxy Tab 3 Kids Will Not Turn On
The device will not power on.
Galaxy Tab 3 Kids is Not Charged
One of the most common problems that Samsung galaxy tab 3 kids have is the charging port will not charge the battery. This means that the charging port is damaged and needs replacement.
Charger is Not Working Properly
Most of the other Samsung products will require 1 amp adapter while Samsung Galaxy tab 3 kids will need 2 amp adapter. Galaxy tab 3 kids is considered above average in size, which is why it needs a 2 amp adapter to charge it for the battery to work properly.
Battery is Not Working Properly
Every battery has a operational life span. A possible reason that the battery is not functioning is because it has reached its life span. In order for the tablet to function, battery replacement is necessary.
Motherboard is Not Working Properly
The motherboard appears to be damaged. The motherboard is like the device’s brain, which means that if it is damaged, it needs to be replaced for the device to work.
Screen is Frozen
The screen on the device is unresponsive and is stuck on one frame.
Battery Life is Low
Every battery has an expected life span that it will no longer work after that. The battery has been overused, which means that the battery needs to be replaced. Another way to extend a battery’s life span is to avoid overcharging the battery.
Cracked / Damaged Screen
The screen might be physically broken or damaged. Physical damaged screens are caused on impact. This will only prevent the device from working if the screen is severely damaged. The best solution to this will be replacing the cracked screen with a new one.
Backlit Light is Not Working Properly
The backlighting helps the user see the screen, it has outlived its life expectancy or got damaged, which makes it hard for the user to see if the device works or not. The backlit light needs to be replaced.
Camera Unable To Take Photos
The Camera on the device is unable to take pictures correctly.
Camera Application Crashing
A good reason would be having a lot of applications opened at once, close most of the applications that are not being used. Low battery could be a possibility and always make sure you have the up-to date update.
Camera Lense Dirty
If the photos are coming out blurry clean the lens with a soft cloth as it maybe a solution to the problem.
Camera Physically Broken
The camera maybe broken due to the device being dropped, replacing it with another lenses or camera would be the only answer to fixing this problem.
Physical Buttons Not Responsive
The devices physical buttons on the side of the device are not adjusting the volume, locking the screen or turning the device on or off.
Sensor Not Working Properly
The sensor has out lived its life expectancy or has physical damage and needs to be replaced.
Connector is Dirty
The connector is too dirty to detect the signal traveling from the sensor to the mother board.
Taylor Bratsch
6,186 Reputation
14 Guides authored
4 Comments
Can any one help me , the buttery showing 100% then since then not booting I changed a new battery but still the same , any one can help me what could be the problem.
Thanks
khaledm2012 - Reply Share
My tablet sim is locked how should I unlock it for free
Omer faisal - Reply Share
My daughter's tablet won't reboot, and has lines…..can someone help me
wendydotolo - Reply Share
This tab will power on but only go's as to were the word Samsung is across the screen, Samsung light's up and go's dim but it won't go any farther than that . If anyone can help me it would be appreciated big time
pjsmart6921 - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,810
