Battery Issues
Your Tablet Will Not Turn On
Device Doesn't Have Enough Power To Turn On
If your tablet doesn't turn on, you should check that your tablet was correctly charged. To do this, charge the tablet for one hour using the factory charger. Make sure the charger remains connected the entire time. Seeing a charging symbol will confirm that charger remained intact. After an hour, remove the tablet from the charger and attempt to turn it on. If This doesn't fix the problem, you could have a battery that doesn't hold its charge.
Battery Doesn't Hold It's Charge
If your tablet won't turn on after removing the tablet from the charger, then you might have a battery incapable of holding its charge. To make sure this is or is not the case, connect and charge the device for one hour using the factory charger. You should see a charging symbol on your screen during this time. Disconnect the charger and attempt to turn in on by holding the power button for 15-20 seconds. Repeat this step a few times. If nothing is resolved, replacement of the battery is suggested.
Headphones/External Speaker Issues
Sound Not Being Played Out Of Headphone Jack Or Connected Auxiliary Cord.
SD Card
Lack of sound through the internal speaker or auxiliary cord could be because of your SD card. The first thing you should try it to remove the SD card and re-insert it. If this doesn't work, take out the SD card and restart the tablet. Once the tablet is turned on music should play out the headphones or speakers. Then re-insert the SD card.
If you have a Sandisk SD card you should replace it. These SD cards are known for having problems with Samsung Tablets.
Settings Issue
If your tablet is unable to play sound through the internal speaker or the auxiliary cord, your settings could be wrong. The best way to reset your settings is by doing a reset to factory settings.
Doing this, will cause all apps and other items to be deleted
Wi-Fi/Internet Connection Issues
Tablet Does Not Connect To Internet And Cannot Load Webpage/Apps
Wi-Fi Not Connecting
If the Wi-Fi isn't connecting, It could be either your tablet unable to connect to the Wi-Fi or your router unable to send the signal to the device. To ensure it isn't the tablet, you should first make sure that your settings allow for connection of Wi-Fi. You do this by going to Settings>Connections. You must make sure that the Wi-Fi allowance button is turned on. If your router does not appear, tab the Refresh Button or the Scan Button. If the router still doesn't appear, your router might not be sending out a signal. Go to your router and make sure power is on. If that is not the issue, you should reset the router yourself or have someone for your internet provider complete the task.
Webpage/Apps Not Loading
Your Device may indicate the that you are connected to Wi-Fi but your Apps and Webpages are not loading. The first thing you should do is make sure that your router is able to provide the connection required. Your service provider should be able to determine that for you. After you have confirmed it is not a service problem, go to the Connections tab in your tablet's settings. Under the data usage, ensure that the mobile data box is checked. At this point you should go check your apps and webpages. If the webpage does not load, go back to data usage settings. Below The mobile data is limit mobile data usage. If it is checked, scroll down to the data usage graph. There will be a red line indicating the limit of your mobile data usage. If the graph is at the red line, you have reached your mobile data cap. Unchecked the “limit mobile data usage” tab and check to see if the webpage loads.
WARNING: GOING OVER YOUR DATA USAGE COULD CAUSE OVERAGES ON YOUR BILL
Inputs Are Unresponsive
Certain Inputs Are Not Responding
Volume Won’t Adjust
If your volume inputs aren't responding, it is likely that your buttons could be stuck in position. If you can see that the button is stuck in an up or down position, try to free it from that state. You may have to open up the case to free it from that state. If the button is freed from its position and persists to not work, there may be a connection problem between the button and the motherboard
Home Button Unresponsive
If the home button is unresponsive, it could be that the button is stuck in position. Repeatedly press the button to dislodge it from its position. If this can not be done from the outside, you may have to open the tablet to get to the home button. If problem persists, there is a connection issue with the button and the motherboard in which you must open the tablet to fix.
Screen Unresponsive
Screen is unresponsiveness is common if the screen is cracked. The cracked screen might have damaged the LCD digitizer and cause it to be unresponsive in some or all areas. If the screen is unresponsive but not cracked, you must check to see if the digitizer is connected within the tablet. If you found that the digitizer is in tact and properly connected within the device, a replacement part might be required.
Camera Not Working
Nothing Happens When Attempting To Take A Picture
Broken Camera
If either of your cameras aren't working, it could be that there Cameras are broken. Replacement of these cameras will be required.
Software issue
It could be that the reason behind your faulty camera is a software problem. Your software could be corrupted. Try re-installing the operating system according to the manufacturer's specifications.
Broken motherboard
If the previous options have not fixed your device, it could be that your mother board is faulty and is in need of replacement.
13 Comments
My tab 3 can not detect sattelites
edilberto soteo - Reply Share
So it’s an issue the battery is fully charged I did a reset it drained battery out I recharged it shows only the full battery when I hit the home button, the power and volumes do not respond…the screen shows my finger strokes but won’t go to home page…
utubular utubelover - Reply Share
Help? Any way to make this work?
Battery is charging can get it to down load info do not turn off target it only has a power button and up and down bottom no home bottom
No sound
Cheeseanddebra Rollins - Reply Share
Webpage not available
Faith Johnson - Reply Share
