Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Poor Battery Life
The phone’s battery level decreases at a much faster rate than expected.
Display Brightness
Having the display brightness on high can cause battery drainage. To lower the display brightness, go to Settings → Display → Brightness . Adjust the brightness level to a lower setting to decrease battery usage.
Always On Display
The Always On Display, or AOD, will cause battery drainage since the screen will always be on. To turn off the Always On Display, go to Settings→Display→Always On Display . Turning off the Always On Display will decrease battery drainage as the screen will only be on while in use.
Power-Hungry Apps
Some apps like Facebook, Snapchat, and Netflix constantly run to communicate with servers and download new content. To check if any apps on the device cause battery drainage, go to Settings → Device Maintenance → Battery → Battery Usage. You should see a list of apps that consume the most battery power for a certain period of time. Uninstall or modify an app’s behavior so that it does not constantly download new content.
If there are apps in the list on the 'Battery Usage' page that you did not install or do not recognize, they may be components of a malware attack and cause battery drainage. Uninstall these apps immediately.
Turn off automatic uploads for apps or backups. Review each app’s settings and checking to see if any are set to automatically upload or refresh. If you use Samsung Cloud services, change the settings under 'Samsung Cloud' to OFF for apps that you do not want uploading automatically.
Corrupted Data Cache Partition
The cache partition can become corrupted by software updates.
Boot the device in Recovery Mode and wipe the cache partition. Wiping the cache partition will rule out the possibility that the cause battery drainage is caused by corrupt caches.
Turn off the device by pressing and holding the Power/Lock button, then select 'Power Off' to confirm.
Note: If you are unable to access the screen to restart the device or if it becomes unresponsive, press and hold the Volume down and Power/Lock buttons simultaneously for 10 seconds, until the device restarts.
  1. Press and hold the Volume Up and Bixby button (the button below Volume Up and Volume Down) simultaneously, then press and hold the Power button.
  2. When the Android logo appears, release all buttons.
  3. ‘Installing System Update’ will appear for 30-60 seconds before showing the Android system Recovery Menu options.
  4. Press the Volume Down button until ‘Wipe Cache Partition’ is highlighted.
  5. Push the Power button to select.
  6. Using the Volume Down button, highlight ‘yes’ and press the Power button to select.
  7. When the wipe cache partition is complete, ‘Reboot System Now’ is highlighted automatically.
  8. Press and hold the Power/Lock button until the screen lights up to restart the device.
Corrupted Operating System/Software
If you are still having issues with your device, you may need to complete a Factory Data Reset. This will erase all data on your device and restore it to factory settings.
Note: A Factory Data Reset will revert the device back to factory settings. This means that all personal data, preferences, settings, and content will be permanently erased. Save (backup) important data before proceeding with the Factory Reset.
After backing up all personal files and data, disable the Factory Reset Protection so you will not be locked out of your device after the reset.
To disable Factory Reset Protection, sign out of your Google ID on the device and elect to not sign in with a Google ID into any Google devices. When you sign in with a Google ID to any service and set up any password (i.e. PIN, Pattern, Finger Print, etc.), you automatically turn on anti-theft.
To sign out of your Google ID:
  1. From the Home screen, swipe up on an empty spot to open the Apps tray.
  2. Tap Settings→ Cloud and Accounts→ Accounts→ Google.
  3. Select your Google ID email address if multiple accounts are setup. If you have multiple accounts setup, repeat these steps for each account.
  4. Touch the icon with three small dots → Remove Account → Remove Account.
From the home screen, swipe down from the Notification bar then select Settings → General Management → Reset → Factory Data Reset → Reset → Delete All.
Alternate Master Reset Method
  1. With the device powered off, press and hold the Power/Lock, Volume Up, and Bixby button (the button below the Volume Up and Volume Down buttons) simultaneously until the Android Recovery screen appears.
  2. Push the Volume Down button until ‘Wipe Data/Factory Reset’ is highlighted, then push the Power/Lock button.
  3. Press the Volume Down button until ‘Yes’ is highlighted, then press the Power/Lock button to begin the reset process.
  4. When the Android Recovery screen displays again, ensure that ‘Reboot System Now’ is highlighted. Press the Power/Lock button to select.
If the problem persists after the Factory Reset, the device is defective. Return the device and have it replaced.
Not Charging when Plugged In
When the device is plugged in to a power source (i.e. an outlet or a portable charger), it does not charge.
Third-Party or Faulty Charger
For newer Galaxy phones, the chargers are designed to have a fast charging capability. Ensure that the charger being used is the one specific to the model of your device.
Check both ends of the charger. Clean out any debris or lint that can be causing a disruption in the connectors. To further inspect if the charger is the problem, connect your device to a computer. If the device is detected by your computer, then there is a problem with your wall adapter, and your charging cord is in working condition. If the device is not detected by your computer, consider buying a new charging cord that is specific to the model of your device.
Third-Party Apps
To rule out the possibility that third-party apps are causing the inability to charge, boot your device in safe mode to temporarily disable all third-party elements.
  1. Turn the device off. Press and hold the Power/Lock button, then select 'Power Off.' Select 'Power Off' to confirm.
  2. Press and hold the Power button past the model name screen.
  3. When 'SAMSUNG' appears on the screen, release the Power button.
  4. Immediately after releasing the Power button, press and hold the Volume Down button.
  5. Continue to hold the Volume Down button until the device finishes restarting.
  6. Safe mode will display in the bottom left corner of the screen.
  7. Release the Volume Down button when you see 'Safe Mode.'
If your device runs normally in Safe Mode, an app is responsible for the lag. Consider apps that were installed prior to the lag issue, update these apps, and reset or uninstall the app if updating the app does not solve the issue.
Defective Battery
After utilizing the solutions listed above, if the device still does not charge when plugged in, there is a chance that the battery itself is faulty. Replace the battery using this guide.
  2. Tap Settings → Cloud and Accounts → Accounts → Google.
  3. Select your Google ID email address if multiple accounts are setup. If you have multiple accounts setup, you will need to repeat these steps for each account.
  1. With the device powered off, press and hold the Power/Lock, Volume Up button, and Bixby button (the button below the Volume Up/Volume Down buttons) simultaneously until the Android Recovery screen appears.
WiFi Disconnects or Slows Down
The device randomly disconnects from WiFi or does not connect at all.
WiFi Switch is Turned Off
If this setting is not turned on, then your device will not automatically connect to WiFi.
Go to Settings → WiFi. Turn the switch to 'ON'.
Software Bug
The device's system might need a reboot. To restart the device, hold down the Power/Lock button until you see the 'Power Off' and 'Restart' options. Tap 'Restart.'
Outdated Operating System
An outdated operating system can be the cause of the WiFi not connecting to your device.
To update your device, go to Settings → Software Update → Check for Update. If your device has an update available, install the newest software update.
  1. With the device powered off, press and hold the Power/Lock, Volume Up, and Bixby button (the button below the Volume Up/Volume Down buttons) simultaneously until the Android Recovery screen appears.
Device Randomly Restarts
The device restarts randomly, often multiple times a day.
Software Bug
A software bug can often be fixed with a forced restart. Force restart the device by pressing and holding the Power and Volume Down buttons for 10 seconds or until the device powers off. Release the buttons when the Samsung start up screen appears.
Liquid Damage
Checking for liquid damage:
  1. Look into the USB charging port for any traces of liquid.
  2. If there is moisture present, clean out the port with a tissue or a cotton swab.
  3. Remove the SIM tray using a paperclip to check the Liquid Damage Indicator (LDI).
    • If the LDI is white, the device is free from liquid damage. If the LDI is red or purple, the device has had liquid inside of it.
  4. If there is liquid damage, see how to replace affected parts with the Motherboard Replacement Guide or I/O Daughterboard Replacement Guide.
Third-Party Apps
To rule out the possibility that third-party apps are causing the restarts, boot your device in safe mode to temporarily disable all third-party elements.
Your device will not restart randomly in safe mode if the issue is caused by an app.
  1. Turn the device off. Press and hold the Power/Lock button, then select Power off. Select 'Power Off' to confirm.
  6. 'Safe Mode' will display in the bottom left corner of the screen.
If your device runs normally in Safe Mode, an app is responsible for the restarts. Consider apps that were installed prior to the restart issue, update these apps, and reset or uninstall the app if updating the app does not solve the issue.
Old Versions of Apps
  2. Tap 'Play Store.'
  3. Select Menu → My Apps . To keep your apps automatically updated, tap Menu → Settings then enable Auto-update apps .
Choose one of the following options:
  • Tap Update [#] to update all applications with updates available.
  • Tap an individual application and then tap Update.
Corrupted App Cache and Data
  2. Tap Settings → Apps.
  3. Choose the desired application in the default list or tap the icon with three dots → Show system apps to display pre-installed apps.
  4. Find and select Storage → Clear data → OK → Clear cache.
Malicious Apps
  4. Select the desired application → Uninstall → Uninstall.
Corrupted Caches
Boot the device in recovery mode and wipe the cache partition. Wiping the cache partition will rule out the possibility that the restarts are caused by corrupt caches.
Note: If you are unable to access the screen to restart the device or if it becomes unresponsive, press and hold the Volume down and Power/Lock buttons simultaneously for 10 seconds or until the device restarts.
  1. Press and hold the Volume Up and Bixby button simultaneously, then press and hold the Power button.
  3. ‘Installing System Update’ will appear for 30-60 seconds before showing the Android system recovery menu options.
Defective Battery
If the problem persists after trying all of the listed fixes to the software of the phone, there is a chance that the battery itself is faulty. Replace the battery using this guide.
To disable Factory Reset Protection, sign out of your Google ID on the device and elect to not sign in with a Google ID into any Google devices. When you sign in with a Google ID to any service and set up any password (i.e. PIN, Pattern, Finger Print, etc.), you automatically turn on ant-theft.
Display Has a Red Tint
When powered on, the display has a slight red hue.
This issue was first identified by Samsung; Samsung promptly released a software update to correct the problem.
To update your device, go to ‘' Settings → Software Update → Check for Update. ’’ If your device has an update available, install the newest software update.
Display Settings
It could be that the color settings of your display have been changed. To check, open ‘’Settings → Display → Screen Mode. '' Ensure the color sliders are all at the same level. If they are go back to ‘’Display → Blue Light Filter’’ and check to see if the Blue Light Filter is enabled; if it is, disable it.
Faulty Display
If the problem persists after updating the software of the phone and checking the color levels of the display, there is a chance that the display itself is faulty. Replace the display using this guide.
There is Lag on Home Screen
When attempting to open applications from the home screen, the device reacts after a short period of time, rather than immediately. Or, when scrolling through the settings, the motion is delayed.
Third-Party Apps
To rule out the possibility that third-party apps are causing the delay, boot your device in safe mode to temporarily disable all third-party elements.
Your device will not lag in safe mode if the issue is caused by an app.
  1. Turn the device off. Press and hold the Power/Lock button, then select 'Power Off' to confirm.
  3. When “SAMSUNG” appears on the screen, release the Power button.
Outdated Versions of Apps
  2. Tap Play Store.
  3. Select Menu → My Apps. To keep your apps automatically updated, tap Menu → Settings then enable Auto-update apps.
Malicious Apps
Corrupted Caches
Boot the device in recovery mode and wipe the cache partition. Wiping the cache partition will rule out the possibility that the lag is caused by corrupt caches.
Wipe the cache partition using these steps:
  1. With the device powered off, press and hold the Power/Lock, Volume Up button, and Bixby button (the button below the Volume Up/Volume Down buttons), simultaneously until the Android Recovery screen appears.
Erik Mauk
1,531 Reputation
6 Guides authored
Cal Poly, Team S2-G1, White Winter 2019 Member of Cal Poly, Team S2-G1, White Winter 2019
CPSU-WHITE-W19S2G1
3 Members
132 Guides authored
7 Comments
I have a Galaxy s8 active and my volume buttons are stuck n is causing my phone to stay on safe mode no one knows how to fit it…can anyone else help or what do I need to buy
anduraso1990 - Reply Share
I have just purchased a Galaxy s8 refurbished and since received the sound comes on and off sometimes for a whole day and then without doing anything it will come back on I have checked the sound parameters and the settings without finding anything amiss anyone got a solution ?
David - Reply Share
This is my second re-furbished Samsung S8 active, love them but they both either restart randomly or the Sim card just randomly disconnects...
Gab O. - Reply Share
My husband phone won’t receive calls it says emergency calls only
luke161 - Reply Share
Did y'all ever find a solution? Mine can receive calls but can't make them??
Nathaniel Moreau - Reply Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 46
All Time: 6,055
