Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Power/Volume Buttons Not Working
The phone does not respond when the power button and/or the volume button are pressed.
Button Flex Is Broken
If the physical button does not click when pressed, then the button flex is broken and needs to be replaced.
Driving Mode Is On
If the power or volume button click when pressed but are unresponsive, the issue is most likely software related. If you are unable to turn the phone on, try plugging it into the wall. If the phone does not turn on, you probably have an issue with your charger, charging port, or battery, not your buttons. If the phone turns on when plugged in, you have a software problem. One common issue is that driving mode is toggled on. To check, click the ‘Message+’ app and select ‘menu.’ Here you can see whether or not driving mode is toggled on.
A third party application is interfering
If driving mode is off but you still believe you have a software problem, you may have an app downloaded on your phone that is the cause. To test this, put your phone in ‘safe mode’ by turning your phone off, then pressing and holding the power button until the ‘Samsung’ screen appears. Next, press and hold the volume button until the phone restarts. If the buttons begin working while in safe mode, an app is the cause. Restart your phone to exit safe mode.
Miscellaneous Software Issues
There are many other software-related reasons why your buttons may not be working. If driving mode is off and you are sure that an app is not causing your issues, check to see if your phone’s software is updated by going to ‘settings,’ then ‘about device,’ then ‘software update.’ If the software has already been updated, there may be some form of data on your phone that is causing the issues. A factory reset can test this but be sure to back up any valuable data on your phone before trying this.
Battery Draining Super Fast
The phone's battery life is low, and you have to charge your phone more than twice a day.
Android System Is Using Too Much Battery Power
If your android system is using too much power, switch your phone to safe mode with this guide.
Are Using Too Much Battery Power
Access the devices Usage Manager Battery screen to determine what apps and features are consuming battery power. Uninstall or close apps that are not essential to save power.
Faulty Battery
If the battery is swollen, replace the battery using this guide.
Battery Won’t Charge
The phone will not respond or show any sign of powering up.
Dirty Power Port
Clean the charging port of the phone first making sure that it is free from any dirt or debris. You can use a can of compressed air to clean the port.
Charger Is Not Plugged In Correctly
Ensure the charger is plugged in correctly. Make sure both ends of the charging cord are entirely plugged into the phone and adapter.
Faulty Power Charger
If the charger is plugged in correctly, but the phone is still not charging; try using a different charging cord. You can check if the phone can be charged via charging with a computer USB port. If you can, the adapter is faulty. Consider purchasing a replacement adapter.
Faulty Battery
If the phone only powers up when the adapter is plugged in, regardless of charging time, then the battery is faulty. Replace the battery using this guide.
False Overheating Error Message
You are getting overheating error message on your Samsung even when the temperature of my phone is not hot.
Faulty MicroSD Card
Try removing microSD card with this guide.
Faulty Sensor
If the problem persists after the microSD card is removed. It’s very likely that this is a hardware related problem already possibly caused by a faulty sensor in which case you will need to have this checked at a service center.
Camera Not Working
The phone’s camera app will not open up or function.
Corrupted Files or Cache Corrupted
You may have some corrupted files or cache that is corrupted that needs to be cleared in order for camera app to function properly. To clear these files and cache please follow this guide.
Phone Reset
If the previous solution above failed, than you can proceed to reset the phone to solve the issue. This is recommended as a last solution because to do this you will have to backup all of your phone information before you proceed to reset the phone. To reset the phone just follow this guide.
Headphone Jack Not Working
Headphones and speakers do not produce sound when plugged into Samsung Galaxy S4 .
Faulty Headphones
Try the headphones in another device that you know has a working headphone jack.
Faulty Auxiliary Cord
If you are using an auxiliary cord try it on another device with a working auxiliary port.
Broken Headphone Jack
If either of these tests fail, you have a broken headphone jack, follow this guide, to replace it.
Microphone Not Working
Your Samsung Galaxy S4 does not record sound.
Microphone Has Water Damage
Dry your Samsung Galaxy S4 with a dry towel to eliminate any visible traces of water or moisture.Remove battery, Clean all the openings in order to eliminate all possible traces of water and moisture completely. Put your phone into Rice bag or Silica gel packets for at least 48 hours in order to absorb any moisture.
Rubber Cap of Microphone is Misplaced or Out of Order
Open up your phone to access the microphone, to open the phone follow this guide.Make sure the rubber cap on the microphone is in place, if it’s not put it back. If it is cut or damaged replace it referencing this guide.
Microphone is Faulty
If the MIC continues not to work, replace it following this guide.
Erick Vazquez
180 Reputation
1 Guide authored
Cal Poly, Team S18-G1, Livingston Spring 2018 Member of Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Members
96 Guides authored
6 Comments
Good morning, my s7 edge has displayed green background light since and it's not working anymore, what am I gonna do please?
Jide Fatuyi - Reply Share
I am having issues with the incall volume on my samsug s7active has anyone else had this issue
rodney slaughter - Reply Share
Phone display not working
Gail Conwell - Reply Share
What does a triangle with the data symbol in it mean on a S7
poplarlane388 - Reply Share
Or I should say the up and down arrows
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 35
All Time: 4,240
