Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone will not turn on
Oh no!!! Your phone is still napping.
Dead battery
The battery could be out of charge. Plug it into your charging cable and wait a few minutes. Try to turn the phone on.
Bad screen
Phone is on and working just with no screen output. If this is the case your phone should still vibrate or ring if called or texted. Check for signs of the phone being on. If it works, turn off the phone and follow our guide on how to replace the screen.
Bad motherboard
If all else fails then you may have a problem with your motherboard. You can follow our guide to replace it and get your phone working.
Phone is frozen/unresponsive
Screen display is not changing or doing anything when prompted.
Restart phone
Hold down the power button until your phone turns off completely. Wait a few seconds before turning your phone back on.
Remove battery
Take off the back cover of your phone and remove the battery. Wait a few seconds then put the battery back with the cover. Turn your phone back on.
Lack of wireless connection
Wi-Fi!?!?! Where are you Wi-Fi???
Antennagate
Try holding your phone in a different position and take off the case if you have one. Both can block your Wi-Fi.
Relocate
You may just be in a bad spot for Wi-Fi. Move to a different part of the room or go outside.
Restart phone
Battery does not hold a charge
Unknown battery problems.
Check battery placement
Take off the back cover and make sure the battery is in properly. Also make sure the battery is not loose in its spot. If it is loose or not in correctly take it out and put it in so that it fits and in the way it is supposed to be.
Different charging cable/outlet
Your cable could be faulty. Try using a different charging cable to see if that does it. If not try a different outlet to charge your phone from.
Replace Battery
Your battery is bad and you need to buy a new one and put that into your phone.
Minor water damage
My phone went swimming!!!!!!
Immediate treatment
Find a cloth or other item to dry your device. You are going to use this item to dry your phone as best as you can. Then remove the back and take out the battery. Place the phone, battery and back cover in a porous material like rice to get the last of the water out.
Author
with
Kasey
27 Reputation
0 Guides authored
1 Comment
If my phone comes on but screen is still black. If it doesnt have a sim card in it would that make a difference, or not!
Mysti - Reply Share
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 1,404
