Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone will not turn on
No matter what you do the phone will not turn on.
Dead battery
Connect the phone to a power source through an undamaged, UL certified power adapter. Give the phone a few minutes and see if it turns on. If it does not, replace the battery with a new battery, using this guide.
Bad display
The phone vibrates or make sounds, but the screen stays dark. The phone may be functioning but the display screen might be broken or malfunctioning. A replacement screen is likely needed.
Touch screen not working
The touch screen is unresponsive to my touch, or does not turn on at all.
Screen unresponsive to touch
This can be several reasons, first make sure to use just your bare fingers to try and operate the screen. Wearing gloves may cause the screen to not register your touch. If screen continues to be unresponsive a replacement may be needed.
Note: this can occur because the screen and your fingers are cold. the heat from your fingers is how the phone reads your touch.
Broken screen
If your screen is cracked or broken this can cause the screen to be unable to read your touch due to internally damaged components. A replacement screen may be needed.
Phone will not fully charge/gets hot while charging
No matter how long the phone is charging, the battery life is never full
Bad Battery
Connect the phone to a power source through an undamaged, UL certified power adapter for four hours or more. Monitor the device for excessive heat. If the device does not charge to full or gets hot to the touch, replace the battery with a new battery using this guide.
Bad Charging Port
With a known to be good battery, phone will turn on but will not charge or charge fully. Device gets hot while charging. The charging port may be damaged or corroded. Replace the charging port of the device using this guide.
No audio/audio distortion
The audio sounds distorted or cannot be heard at all.
Sounds settings
Turn the phone ringer volume up to maximum level through the phone settings. Programs and alarms have separate volume controls, pull up the settings for each one individually.
Faulty speaker
Volume of the device is on and at maximum level, audio quality is poor or non-existent. The speaker may be damaged. Replace the speaker using the provided guides. For front facing speakers use this guide. For audio speakers use this guide.
Device will not take pictures/pictures are distorted
The photos taken by device are black or heavily distorted
Damaged lens
Camera lens has a crack or visible physical damage. Replace the camera lens using the provided guides. For front facing camera use this guide. For front facing camera use this guide.
Camera will not focus
Modify the camera settings to bring photo into focus. If the photo will still not focus, lens may have internal damage. Replace the camera lens using the provided guides(s). For front facing camera use this guide. For front facing camera use this guide.
Author
with
Aaron Fulton
1,246 Reputation
3 Guides authored
USF Tampa, Team 17-2, Blackwell Winter 2016 Member of USF Tampa, Team 17-2, Blackwell Winter 2016
USFT-BLACKWELL-W16S17G2
4 Members
96 Guides authored
7 Comments
I have a problem with my galaxy mega,after i restart my device,i can't download anything from google play and my clock is going freeze,i already do a factory reset but got a same problem and after 5 to 8 hours its become normal,can u help me settle this problem?tq
fai sal - Reply Share
my galaxy samsung mega cant send text or receive text.
terso_lorejo - Reply Share
My galaxy mega cant send or receive text
My galaxy mega 6.3 has vertical lines on the screen.
Dinora Peguero - Reply Share
There is a blue light on at the top and the att logo on screen and can’t get it to come to main screen.
sugarcanesm - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 4,466
