Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Phone Will Not Turn On
The Phone will not respond or show any sign of powering up.
Phone is Not Charged
Every phone battery will not stay on forever, even if it is a good or new battery. Connect the Micro USB charger to the phone then the USB type A to the the wall adapter then to the wall socket. When the battery charging icon is displayed, the phone is charging. When the phone is turned on, you can always see the battery power level.
Charger is Faulty
The problem may not be from the Phone, it may be from the Charging Cord being used. Try to use the Charging Cord with another device. If it does not work you need to get new Charging Cord.
Faulty Battery
Plug your Galaxy in using a charger that you know works. If the Phone still does not charge, this is a sign of a faulty battery and the battery needs to be replaced.
Calls and Voicemail Will Not Work
The phone is not sending or receiving calls or you may not be able to communicate with the other person
Network is Out of Range
If you've set your phone to use a specific phone provider, occasionally you may not have signal to the network if the selected phone provider is out of range. Contact Phone Provider for assistance.
Speakerphone could be broken
If the above steps does not work, your speaker may be faulty and it should be replaced
Microphone could be broken
If the above steps does not work, your microphone may be faulty and it should be replaced
Buttons Will Not Work
The buttons may not respond or may be broken
Faulty Touch Controls and home button
If you restart your phone and that does not working, your touch controls may be faulty and you need to replaced your home button.
May have Software problems
Try restarting your Galaxy, or resetting to factory settings.
Camera is Not Working
The Camera on the phone may have marks on it or is not showing a picture.
Frame bezel may be cracked
The issue could probably be that the plastic cover over the camera that protects it may be cracked. Touch the plastic over the camera and if you do feel a crack then it may need to be replaced
The Camera is not working at all
If the above step does not work try doing a Factory Reset, if that does not work than Camera is faulty and needs to be replaced.
Turning Off or Freezing
If your J3 isn’t working properly, freezes or is turning off here is what to do. In some cases closing background applications can also be helpful if you continue to face issues.
Soft Reset
A soft reset may help with many issues like freezing and number of other issues. Here is how to do a soft reset on the J3.
1.Turn your device off and remove the back cover.
2.Remove the battery, and wait for 10 seconds before inserting the battery back in.
3.Turn your J3 back on, and see if the problem has been solved.
Try Clearing the Application Cache
Clearing the application cache will clear any saved data from that app and will restart the app to the first time it was installed. To clear the application cache. We’ll show you how below:
1.Tap My Account from the home screen. Swipe left to open up the Device Diagnostics.
2.Tap Power Usage, and tap Battery Usage.
3.Tap on an individual application.
4.Tap App Info, and tap Clear Cache.
*If you’re still having problems, make sure that your device has been updated.
Factory Reset
A factory reset is a drastic method, and it will erase all of the information stored on the device. This includes passwords, images, texts and apps. There are a number of things you can do to backup your data beforehand. It’s strongly advised to make a backup, because it’s easier than starting over from scratch. To do a factory reset:
1.Tap Apps from your Home screen.
2.Tap the Settings option in this menu.
3.Find and tap Backup and reset, and tap Factory Data Reset.
4.Tap Reset Device, and tap Delete All to confirm your selection.
5.Your device will now reset, and it’ll restart once it’s completed.
*This should be seen as a last-ditch effort, so don’t go for it unless you’re sure there’s nothing else you can do.
Errors
When an error is shown on screen
Error 67
If you see an Error 67 the you may have mobile hotspot issues :
Connect to the mobile hotspot but can't browse.
1.Tap Apps from the home screen.
2.Tap Settings, and tap Data Usage.
3.Ensure that the Mobile data switch is on.
If you’re still having issues, it’s advised to soft reset your device, as it should help you to get reconnected with your network
wafaa
157 Reputation
1 Guide authored
USF Tampa, Team S5-G5, Passmore Spring 2018 Member of USF Tampa, Team S5-G5, Passmore Spring 2018
USFT-PASSMORE-S18S5G5
5 Members
60 Guides authored
11 Comments
The app numbers eg email, messages, missed calls does not work ? Advice please.
Robin Parry - Reply Share
My grandson accidently tried to plug my iPhone charger into My Samsung galaxy juno3 PH , and apparently it got stuck in the charging slpot so he yanked i,t out , now i am unablemto fit the Samsung charger into the slot on the phone . The battery itself doesn't seem to have any damage to it because it attempts to power on just not charged enough do to problem previously mentioned . Any sugestions On how to remedy this situation would be greatly appreciated !
Sincerely,
Debrasimmons1958@icloud.co, or
debrasimmons2.ds@gmail.com
Debra Simmons - Reply Share
i believe that you have misunderstood my delema! do to a iphone usb plug being forced into the battery charging slot of my samsung juno3 and getting stuck there and being forcibly removed i can no longer fit my samung usb wire into thw battery charging slot on thebphone
dls5252 - Reply Share
My samsung luna will turn off automatically when calls come in and will freeze and shut off when trying to make calls out.
heather morrison - Reply Share
when I go to make a call it automatically goes to tracfone to add minutes. I cannot make any calls or receive calls.
Don Lauderbach - Reply Share
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 35
All Time: 9,125
