Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Turntable Won’t Play Sound Through the Computer
The Sony PS-LX300USB can’t play sound through computers or their speakers. However, the turntable will still connect to a computer for other functions.
Missing USB Audio Codec Option
If the USB Audio Codec Option is missing from your speaker menu, it was likely chosen as a disabled device. To fix this, go into the Recording Devices, under Sound and Speaker, menu and choose the Disabled Devices tab. Enable the device here.
Turntable Platter Won’t Turn
The platter under the rubber mat on which records rest doesn’t turn or doesn’t appear to turn properly.
Sticky Spindle
Clean the spindle and lubricate it with oil. If the platter now can spin, then the issue was just a matter of friction or a dirty spindle.
Worn out or Broken Drive Belt
If the turning platter has turned before, did you notice any discrepancy between a song’s typical and observed tempos? If so, this could be a sign that your turntable’s drive belt is deteriorated or broken. Remove the platter to reveal the drive belt to inspect it for cracks or major stretch marks. If you see these or if the belt is torn or broken, you need to replace your drive belt. You can see exactly how to replace the belt here: Drive Belt Replacement
Improperly Wound Drive Belt
Remove the rubber mat and turning platter. Verify that the drive belt wraps around the turning platter and hooks onto the motor pulley. If the drive belt isn’t hooked around the motor pulley, hook it around the motor pulley.
Faulty or Run Down Motor
If none of the above solved the problem, you likely need a new motor.
Turntable Won't Power On
The turntable doesn’t show any signs of powering on.
The Power Cord Isn’t Properly Connected
Make sure your power cord is securely connected to your device. If the wiring is loose, you may need to find a local repair shop to correct the wiring.
The Turntable is Manufactured for a Different Country/Voltage Level
Check that the voltage listed in your user's manual under “Specifications” matches the voltage of your outlet. Device voltage depends on for what country it is manufactured. Connecting the device to the wrong type of outlet can fry the turntable’s internal components, forcing you to buy a new device. To avoid this, you can buy a voltage converter that converts the voltage of your outlet to the voltage of your device.
When Recording, It Records Primarily Background Sounds
After trying to record, the playback is random noises or voices instead of the desired recording.
Turntable Recording Microphone not Enabled
In order to ensure that the turntable is recording, go into the sound settings of your computer. Go to disabled devices and look under “recording device” for USB Audio CODEC. Enable this recording device. You can also set this recording device as your computer’s default to ensure that it is enabled the next time you use it.
Other Microphones are Interfering
Computer microphones could be overriding the turntable. Disconnect any external microphones from your computer. Also, disable all internal microphones on your computer. This can be done in the sound settings of your computer.
Distorted Audio
Audio sounds abnormal, out of tune, or off tempo.
Dirty Stylus or Vinyl Record
The stylus may be worn or dirty. Clean the stylus of any dust with a cleaning brush or replace the stylus. The vinyl record may be be dirty. Use a record cleaner to clean the vinyl record.
Worn Out Drive Belt
If the audio sounds lower and/or slower than it should be, the driver belt is likely worn out. You can order a replacement belt online. Here is a guide for how to replace the belt: Drive Belt Replacement
Author
with
Michelle Jakab
633 Reputation
1 Guide authored
Cal Poly, Team S8-G3, Banghart Fall 2017 Member of Cal Poly, Team S8-G3, Banghart Fall 2017
CPSU-BANGHART-F17S8G3
5 Members
60 Guides authored
16 Comments
I have a Sony PSLX300USB that will not play through my computer. the USB CODEC option does show up on my sound tab and is set to my default but the computer does not recognize the device. Help?
D. Camron Mc Intire - Reply Share
go to control panel, find hardware, open up the hardware screen, find the USB CODEC and open up the settings window. click update driver. I did this and then it showed up correctly.
larry souder - Reply Share
Pitch tracker laser won't light up when I switch turntable on. Sometimes flickers.
dhughnegus - Reply Share
My turn table sound is awful coming through the speakers…I purchased a new needle and my record is clean and in great shape..the music from my computer going through the same speakers sound great..what is my problem with the LP?
Mary DeGeoso - Reply Share
My record player is playing too fast, pitch is a little too high. How do I fix this?
Star - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 52
All Time: 11,631
