Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Unable to pair speaker with devices
The device's bluetooth is turned off
If your PC does not recognize the speaker, first make sure that the device's bluetooth is turned on.
The audio cable is plugged in
If you are unable to pair the speaker with your device, first make sure that the audio cable has been removed from the auxiliary jack on the back of the speaker.
Clear the device
If the connection fails when you are trying to connect the speaker and a bluetooth device for the first time, turn off the device, then turn it back on to clear the device name. Then try connecting the speaker to your device again.
Unable to pair speaker with a computer
Outdated bluetooth driver
If your computer's bluetooth is turned on and you continue experiencing issues in pairing the speaker to your PC, try upgrading your computer's bluetooth driver.
Unable to pair speaker with a cell phone
The phone's bluetooth is turned off
If your Android cell phone does not recognize the speaker, first check to make sure that your phone's bluetooth is turned on.
The speaker is paired with another bluetooth device
If your phone's bluetooth is turned on and you are unable to connect your phone with the speaker, make sure that your speaker has not been paired with another device nearby. If that is the case, unpair the speaker from the other device and restart your telephone.
Speaker stops playing
The speaker plays music for a period of time and then stops unexpectedly.
The audio cable has come unplugged
If you are not using a bluetooth connection, make sure that the audio cable is plugged all of the way into the auxiliary jack.
The audio cable is broken
If the audio cable is plugged all the way into the auxiliary jack and the speaker stops playing, the cable itself may be broken. If this is the case, you can solve this problem by replacing the audio cable.
The audio jack is broken
If the audio cable is plugged in all the way into the auxiliary jack, you may have a broken auxiliary jack and will need to replace it using this guide.
Lost bluetooth connection
If you are playing your speaker through a bluetooth connection, check to make sure that it is still connected to the bluetooth device. If not, reconnect it.
Unable to charge speaker
The speaker will not charge.
Broken charger
If you plug the charger into the device and the light on the charger does not light up, you may have a broken charger. Replace your charger with a new one and see if this corrects the issue.
Broken battery
If you plug the charger into the device and the light on the charger lights up but the battery will not charge, it is time to replace your battery with a new one using this guide.
Low speaker volume
The speaker volume is too low.
Volume not turned up
Ensure the volume is turned up by pressing the + key on the device until the volume no longer increases.
Weak speaker
If the volume is turned up all the way and the output is still too low for your liking, replace the speaker component with a different speaker using this guide. Alternatively, you may replace the audio amplifier to one of a better quality using this guide.
Short battery life
The battery life is too short.
Battery is not fully charged before use
Make sure the battery is charged all the way before using. To charge the device, plug the charger into the DC in jack on the back of the device and charge.
Broken charger
Broken battery
Author
with
Kara Falknor
101 Reputation
1 Guide authored
1 Comment
How can I get a new battery for a RF wsp313?
Christopher Jurow - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 31
All Time: 4,904
