Button Won't Press Down
The large gray button that turns the blade refuses to press down.
Lid is Not Secure
The lid of the mini chopper must be locked into place before the button may be pressed. Before assembly, make sure all parts are very clean.
First, make sure the main container is securely fastened. To do so, align the two bumps on the clear container with the grooves on the black body. Twist clockwise until the container locks in place.
The blade must also be in place in order for the lid to fit on the container. Using caution, place the blade over the middle pillar. Push gently while twisting slowly until the blade slides down in place.
Place the lid on the top of the container so that its white dot is pointing away from you and the white dot on the black body is pointing to your right. While pressing down gently, turn the lid clockwise until both dots are aligned and the lid locks in place.
If the lid refuses to lock completely, the locking switch may be jammed. Make sure there is no debris blocking its movement. If the switch is clear and the lid still refuses to lock, try replacing the switch.
Lid is Broken
If lid is missing its side tabs, it is broken and needs to be replaced.
Pressing the Button Yields No Result
The button can be pressed, but there is no response from the blade.
Chopper is Unplugged
The mini chopper must be powered in order to function. Make sure the power cable is plugged into a socket.
Components are Broken
There are many other components that are necessary for the chopper to function. Refer to the Rival Mini Chopper Page for replacement guides.
Blade Has Stopped Spinning
The blade has stopped spinning mid-use for an unknown reason.
Blade is Jammed
The blade may be jammed by food. Note that the maximum capacity of the blender is 1 1/2 cups. If there is more than this amount of food in the blender, remove it before attempting to un-jam the blender.
Make sure the chopper is unplugged. With caution, remove any large pieces of food that may be stopping the blade from spinning. Once the blade's pathway is clear, plug in the chopper again and attempt to spin the blade.
A component may have broken down during the chopper's operation. Refer to the Rival Mini Chopper Page for replacement guides.
Chopper Leaks
The contents of the plastic container come out.
The lid is not properly attached to the plastic container
Before you check, unplug the device. Make sure the plastic lid of the mini chopper is locked into place. This should prevent contents of the chopper form coming out.
There are cracks in the plastic container or lid
Unplug the device and remove the contents of the container. Take out the blade and Inspect the container and the lid for cracks or holes.
Chopper stops suddenly during use
While using the chopper, the blades or motor suddenly stop working.
Chopper becomes unplugged during use
Food is jammed between the blade
Unplug the device and remove the food obstructing the blade. Remove blade if necessary.
Author
with
David Otsu
109 Reputation
1 Guide authored
Cal Poly, Team 4-29, Amido Fall 2013 Member of Cal Poly, Team 4-29, Amido Fall 2013
CPSU-AMIDO-F13S4G29
4 Members
60 Guides authored
3 Comments
How the jerk do you get the container off?
Rick A Hyatt - Reply Share
Is there other part that go with this and is there a manual for this?
Jackie Cozart - Reply Share
How to unlock lid on Rival mini chopper 67BL
katie willis - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 57
All Time: 9,591
